89 TPI wiring harness and ECM in a 91 TBI bird?
Old Dec 3, 2001 | 07:05 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
what kind of problems am i going to come across with this wiring harness and ecm?
vss,vats,speedo?
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
www.gcfba.com (Greater Cincinnati F-Body Association)
http://www.cincyspeed.com/
Old Dec 3, 2001 | 07:29 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Did you pull it out of the car or did you buy it?
Was the harness for a firbird or camaro?
If itw as for a firebird, you're gonna have to relocate the battery to the other side.
(yeah, believe it or not)
It shouldn't be bad I mean. There is really only one of each type of connector.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs F/P gauge, A/F ratio gauge, MSD 6AL, MSD Redline selector.
http://www.joesperformance.com
Old Mar 17, 2002 | 12:04 PM
91banditt2's Avatar
Engine: 5.7 HSR
Ahhhh HorseShiznit
well the problem i'm having is i have no power going to the starter from the ign.switch also when i turn the key i have no power going to the fuel pump.
so am i going to have to put in a different under dash harness?
Old Mar 17, 2002 | 08:59 PM
Jza's Avatar
Jza
I bet that's your VATs acting up. What's your security light doing?
Old Mar 17, 2002 | 09:01 PM
Jza's Avatar
Jza
You should have a dark blue wire going from the VATS module, to pin L on the IP connector, to B6 on the ECM.
Old Mar 18, 2002 | 06:10 AM
91banditt2's Avatar
Engine: 5.7 HSR
where is the VATS mod?
Old Mar 18, 2002 | 08:59 AM
Desert86Roc's Avatar
What harness did you change? Sounds like you only got the engine half of the harness, and then tried to plug the ECM into the existing harness under the dash?
Unless you can verify by detailed examination of a wiring diagram that the inside harness is the same on both vehicles (which it probably is not), then you are either going to have to re-pin the inside harness, or go back and get the rest of the wiring harness from the donor vehicle.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
