Mod questions
Old Dec 6, 2001 | 12:32 AM
Black91GTA's Avatar
Mod questions
Hey, I have a '91 GTA 350 TPI. So far it has a K&N, Hooker Aerochamber catback, an airfoil and a 160 deg. thermostat. I have the chance to get a LT4 Hotcam fairly cheap. What else do I need to get to install the cam? What should I get with it to make it run best?
Old Dec 6, 2001 | 12:47 PM
Black91GTA's Avatar
Would that cam be a good combo with: vortec heads, vortec tpi intake, SLP runners, ported plenum, and SLP 1 3/4 headers? Any power estimates?
1991 GTA 350 Black w/ black leather. 82k miles. Hooker Aerochamer Catback, Airfoil, K&N, TB Bypass...and alot more on the way soon!!
Old Dec 6, 2001 | 02:40 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Unless you plan on throwing a whole bunch of money at your car, the HOT cam won't help you out that much, and will probably make your car slower. Bare minimum requirements to use the HOT cam I would say are
#1. Hi-Flow base
#2. Good flowing heads
#3. 10:1 compression
#4. Chip burning capability
#5. Headers, cat-back
355 c.i.
Dart 180 Heads
Lunati 224/224 cam
Harland Sharp 1.5 rockers
Performer RPM Manifold
Holley 600 cfm double pumper
Hooker Super Competition Headers
Flowmaster Exhaust
Competition Engineering Sub-frame connectors
Tremec TKO
Pro 5.0 Shifter
GM posi 3.42 rear
Hurst Roll Control
13.9@102
http://www.geocities.com/thetpiguy/index.html
chemjoker@aol.com
Old Dec 6, 2001 | 03:03 PM
tpi_roc's Avatar
I half agree with TPI Guy
Right now it wont help, but with the mods you listed It will. I'm not to familiar with THAT cam, but if the duration is at or over 220 you can forget it untill you have some new heads/base.
Good luck!
1985 Iroc-z, 14 second 305, new engine in the works.
Old Dec 6, 2001 | 03:04 PM
tpi_roc's Avatar
(power estimate with all that stuff you listed would be around.... 350hp)
Old Dec 6, 2001 | 09:45 PM
Black91GTA's Avatar
Yeah I wasn't going to put it in until I had those things to install with it. But do I really need to raise the compression to run it??
Frozer!!!
Jan 19, 2024 04:55 PM
haps
Interior Parts Wanted
Sep 8, 2015 10:15 AM
lt1z350
Aug 28, 2015 05:57 AM
PestilenceIV
Aug 20, 2015 02:33 AM
redmaroz
Aug 16, 2015 11:40 PM
