How many sensors on a 1988 TPI ??
Old Dec 5, 2001 | 07:51 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I am picking up a complete setup from a 1988 Iroc and want to make sure I get all of the sensors. If you could tell me what the connector looks like that goes with the sensor that would help also
Old Dec 5, 2001 | 08:43 PM
nblanchard's Avatar
Ok... off the top of my head.. here we go
MAF or MAP
TPS
Crank Position
Air Temp
Coolant Temp Fan
Coolant Temp Computer
Oil Pressure
Oil Sending unit (may be both in one)
Knock Sensor
O2 Sensor
VS Sensor
EGR Sensor? (forund this one when I took the Plenum off)
Input Devices
IAC Valve
Injectors of course
Two Ignition Coil Connectors and Two Distributor Connectors
Fuel Pump
Any I missed guys?
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Dec 5, 2001 | 09:49 PM
Momar's Avatar
Do the tpi's actually have a crank position sensor, I did not think that they did. Where is it if they do. Thanks.
Old Dec 5, 2001 | 10:53 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i doubt that they have a crank postion sensor. i thought only v6's had that sensor...
86',88',89' IROC-Z, 350 TPI, 700-R4
94' Formula, LT1, 6spd
Old Dec 6, 2001 | 11:26 AM
nblanchard's Avatar
Good point.... Then there must be a sensor in the distributor that tells the computer where the engine sits (timing)
Old Dec 6, 2001 | 11:56 AM
Momar's Avatar
I couldnt say for sure but I believe that it is used on mpfi cars so that it knows when to fire which injector and whatnot.
Ben
Old Dec 6, 2001 | 08:29 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
TPI has batch fire injectors
No crank sensor...
Old Dec 6, 2001 | 10:07 PM
Momar's Avatar
I knew it was batch fire and was pretty sure it didnt have a crank sensor, but I wasnt sure what it was used for but like I said that is what I would have guessed.
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
