help with cold start injector
Old Dec 8, 2001 | 07:09 AM
pontiacpete's Avatar
hi guys i just ran into a problem with the cold start injector feed pipe the oring that screws into the fuelrail went bad causing a fuel leak can anyone please help me where to find a new replacement as it is a wierd shaped rubber o ring does gm offer a replacement or is it discontinued need to fix problem asap since registration is due any part numbres would be widely appreciated thanks
Old Dec 8, 2001 | 12:34 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by pontiacpete:
hi guys i just ran into a problem with the cold start injector feed pipe the oring that screws into the fuelrail went bad causing a fuel leak can anyone please help me where to find a new replacement as it is a wierd shaped rubber o ring does gm offer a replacement or is it discontinued need to fix problem asap since registration is due any part numbres would be widely appreciated thanks</font>
i got mine from chevy dealer. don't remember the part number. it was a year ago.
mrrjjdh03@aol.com moderator at www.fl-thirdgen.org
Old Dec 8, 2001 | 03:22 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
hi-yes i have the part # for you-it is a small g.m. kit with like 3 o rings in it-its at my shop, and im home now-i will be going to my shop later and will post the part # that i find on the bag. gimme 1-2 hours.hope it will still be of assistance then.
1985 IROC Original Owner. Roller 406-4 bolt superram,p600b,1LE brakes,art carr,1 3/4 slp,blablabla-only 26k original miles and aint never been driven in the rain-swappin to SD as soon as burner gets here.
Old Dec 8, 2001 | 04:40 PM
here ya go-part #17111954 includes 3 o-rings.also if i recall properly, it dosent have the o-ring that seals the threaded adapter to the fuel rail.just from the small hard line to the cold start valve at the runners.hope this helps. seeya
Old Dec 8, 2001 | 07:56 PM
thanks for info guys im relieved there are replacement parts for this cold start injector iwill try first thing Monday morning getting a hold of parts thanks again
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
