now that i have tested dam near everything
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
i have a stock l98
i have been chasing a rough idle for weeks now .
here are the symptoms .
when you first start the car it stalls, try it again it will run but it runs rough and the motor shakes the whole car . for about the first 5min of driving the car smokes , seems like oil smoke and the exhaust smells . if you drive it and let it warm up it gets alot better and runs pretty good (but still has smelly exhaust) .
this is what i have done so far ,
checked codes - none .
tested ALL sensor's according to GM shop manual - all good .
tested fuel pressure - good .
tested plugs/wires/cap/rotor - good .
hooked up to a snap on scanner - all seemed within range (im no expert with 1 and was on limited time with it) .
used carb cleaner to check for vacuum leaks - found none .
here are things that have been replaced within the last yr .
injectors
fuel pressure regulator
IAC
CTS
EGR valve
this seemed to happen all of a sudden out of nowhere and i am running out of ideas , what would you do next ?
injectors
IAC
CTS
EGR valve
Car: 1989 IROC-Z
Transmission: Th700R4
Re: now that i have tested dam near everything
Sounds pretty much as my problem : https://www.thirdgen.org/forums/tpi/...ctors-now.html
Or what do you think ?
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what color is the exaust gray black blue
what is the fuel preasure set at
where is the timing set
check the tps .54
check the tps .54
Car: iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.43
smoke looks blueish .
timing is at 6 degrees and does not jump around .
TPS is set correctly and i was able to confirm that when i had the scanner .
RedLeader289
May 28, 2019 01:47 PM
