Another carb conversion intake option for TPI guys
Old Dec 9, 2001 | 10:37 PM
Guido's Avatar
Car: 2000 Trans Am
This is my intake setup. It consists of:
-Accel Pro Ram base
-Presciosn Turbo 110 degree cast elbow
-90 mm accufab mustang TB
To run this I need to convert to Mustang TPS and I had to buy a housing that bolts to the TB for GM IAC, i will also have to come up with some kind of throttle cable setup
-86 IROC
-=ICON Motorsports=-
Old Dec 10, 2001 | 12:46 AM
Tas's Avatar
Tas
awesome
-Tas
'89 Formula WS-6 made in Van Nuys, CA, U.S.A.
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Dec 10, 2001 | 04:18 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Looks pretty good. That elbow looks like it would flow better than Accels elbow. Accels 90 degree bend looks kinda abrupt, where as yours transitions smoothly.
How's the hood clearance? Do you have to use a cowl hood? Also is it pretty easy to adapt the Ford TPS to GM electronics?
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Dec 10, 2001 | 07:17 AM
Guido's Avatar
Car: 2000 Trans Am
You need a cowl hood to clear it.
I havent done the TPS yet but it should not be tough. The ford one is 3 wire so it should only be a matter of getting the correct weather pack connectors to make an adapter harness.
Old Dec 10, 2001 | 08:09 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
Is there anyway that you are going to use the cowl hood for the induction? or are you just going to use the cowl for the clearance?
Later,
Jesse
85 Z28, 305 TPI A4
pretty stock with a few toys
15.43 @ 89.7 mph (3600 ft)
14.75 @ 94 mph (altitude corrected)
http://photos.yahoo.com/j_hougnon
http://screamindeamin.cz28.com/images/jesse/
Old Dec 10, 2001 | 09:17 AM
Guido's Avatar
Car: 2000 Trans Am
Im using it for clearance, weight savings, and good looks.
Im putting a large single turbocharger on my car this winter so thats the induction.
Old Dec 10, 2001 | 10:32 AM
cort351w's Avatar
how much does that induction setup (not the turbo) cost, Guido?
Old Dec 10, 2001 | 11:05 AM
Guido's Avatar
Car: 2000 Trans Am
Pro Ram: #74139 with fuel rails $400 from jegs
Elbow: $180 from Precision Turbo www.precisionte.com
TB was $210 from Pro Mustang www.promustang.com
the IAC adapter was $57 from precision turbo.
I still need to figure out what Im going to do about the throttle cable. Im going to need something custom I think.
Old Dec 10, 2001 | 11:11 AM
Momar's Avatar
What is that metal plate in front of the engine for?
Old Dec 10, 2001 | 11:42 AM
Guido's Avatar
Car: 2000 Trans Am
Its called a motor plate. What it does is replaces the motor mounts. There are a couple ways of doing this.
-Weld angle to the frame and drill holes through it and the plate to hold the plate.
-use rollcage bars through firewall to hold the plate in place with tabs welded onto the bars and bolt through
It clears up space under the engine for headers.
Old Dec 10, 2001 | 02:20 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
DOOD Stick with a set up and get that running right before changing it!! aaaargggg!!!
Looks good so far man
Kat
Old Dec 10, 2001 | 02:40 PM
-=Jeff=-'s Avatar
Car: 1990 Corvette ZR-1
Engine: LT5
Transmission: ZF6
<font face="Verdana, Arial" size="2">Originally posted by Kat:
Kat
</font>
LMAO!!!!
-=Jeff=-
89 Corvette Coupe White with Black Grand Sport Stripe
Check out My '89 Vette
Old Dec 10, 2001 | 03:04 PM
Guido's Avatar
Car: 2000 Trans Am
Haters!
It was sort of a split decision. Either
1.) upgrade to a cog pulley setup and have s-trim rebuilt with heavy duty bearings or spend $2600 on a t-trim compressor
2.) build the turbo system with a LOT more potential, no damn slipping belt, and not a lot of difference in money
i went with 2. of course. I am hoping to be running 9.80's this year.
Old Dec 18, 2001 | 03:49 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
nice!
that efi setup is very nicely done. i'm considering going along those lines myself. I was gonna go with vortec heads and miniram, but i might be going with different heads, and that rules out ramjet. So i've been considering carb-style. And it's certainly affordable. Keep me posted on the throttle cable issues. I don't think it should be too horrible to rig something simple up.
Old Dec 19, 2001 | 08:19 AM
GRENDLE's Avatar
hey that looks bitchin, are there any other alternatives to the standard TPI set ups , i'm really not into spending $800 for an intake and runners to make an extra 30 HP. i'd rather spend $500 on a nitrous kit and get 150 HP, or go another route like you. what kind of mods are needed to put a set up like that on an 86 TA (computer related) ? do you have to use a stand alone computer and harness? and what do the emissions guys say about that setup? sorry so many questions, i'm still new to the tpi thing.
Old Dec 20, 2001 | 01:07 AM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Grendle does has some very good points! I want to install the same type of setup on my tpi 383. Right now the stock intake only allows me to run my motor up to 4300rpm! Please let us know about the throttle cable & 700r4 cable, wouldnt want to burn the tranny up with a sloppy cable install. Does the stock electronics work with this install?
Old Dec 20, 2001 | 12:25 PM
Guido's Avatar
Car: 2000 Trans Am
I imagine the stock ECM would work. Youd probably want some kind of custom PROM burnt to support the shifted powerband.
Im not using a 700R4 so no cable to route. Using a TH400.
Im going to need a cowl hood. Im not so sure that a smaller one is going to work either.
Old Dec 20, 2001 | 01:14 PM
TheWraith's Avatar
Engine: 355
there's no reason why the stock ecm wouldn't work. same animal, just a different approach, but definitely a custom chip.
That thing is tall! out of curiousity guido, why did you decide on that elbow and tb? After doing a little homework, i'm gonna use the same intake as you, but with the accel elbow and a twin 58mm tb. Gotta figure that would give back some hood clearance, and it helps a lot in the cable routing/wiring department, because it's a stock style TB.
For a cowl hood that gives you some serious room to work, there's always the vfn fiberglass hood that the meanyellow z had. like a 6" cowl and it looked pretty good too.
Old Dec 20, 2001 | 09:29 PM
TPI_Guru's Avatar
You ONLY want 9.80s?
you better plan to go faster than that if you want to keep up with my buddy next year when he gets done with his motor, he plans on flyn' past and LANDN' on your turbo crap with his nitrous motor
COME GET SOME
Old Dec 21, 2001 | 12:39 PM
GRENDLE's Avatar
sounds cool, humm....... i think for now though i'm going to see just how far i can push the stock tpi set up with porting and some other tricks. but i refuse to shell out $1000 + for a stock intake setup. i can build a new motor for that . i'll go carb first
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
stalkier
Aug 7, 2015 04:49 AM
