ACCEL injectors
Old Jun 22, 2008 | 08:48 AM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
ACCEL injectors
i just want a good stock replacement set of injectors. would these be a good value?
thanx!
Old Jun 22, 2008 | 09:36 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: ACCEL injectors
thanx!
. I have a brand new set of 19lb 2nd design
accells in my toolbox. i paid 300.. I will sell them to you for 200.00 or best offer all 8 never installed. my 89 blew up so i put in a 5.7 and got stuck with these.
thanks
frank
Old Jun 22, 2008 | 06:02 PM
Eightyninef's Avatar
Re: ACCEL injectors
i have a set of 2nd design accel's. 1000 miles on them. $150 shipped.
the 1st design accels had major problems.
Old Jun 23, 2008 | 11:51 AM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
Re: ACCEL injectors
Stay away from Accels and save your money, I just installed a set of 19lb injectors for $135 from Jon at fuelinjectorconnection.com and the car runs like an aminal. My 305 had 3 bad injectors, I called Jon and ordered, received my 8 injectors in about 3 days, great service and product, give them a look.....
The $135 are backed for a year or go with the Blue Demon's for $169 that are guaranteed for 3 years...still a great deal
Old Jun 23, 2008 | 04:17 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Re: ACCEL injectors
,Jon is really great to talk to, He really wanna help you with your problem. You got the Bosch III injectors to (22lbs) that you could use if you are able to reprogram your prom to 22lbs injectors. They flow really well. Great spray pattern
Gonna put those on my car after I went thru inspection.
Old Jun 23, 2008 | 04:25 PM
tpi user's Avatar
Re: ACCEL injectors
good guy great prices
Old Jun 24, 2008 | 10:26 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: ACCEL injectors
Stay away from the Accel injectors. There have been several posts over the last year how bad they are, that 1 or more fail in a few months usage.
Buy the Ford 19#/hr EV1 injectors from Summit Racing. The Ford injectors are the best most reliable injector we have. (Of course, this has nothing to do with the fact that I work at Ford, at least until the August 1st salary cutback.) You will get them in 2 days by ground shipping, most likely. I get stuff from Summit in one day.
Old Jun 24, 2008 | 11:39 PM
Re: ACCEL injectors
accel revised there injector line. now they are made by standard motor products.
the older accels had their problems.
Old Jun 29, 2008 | 02:21 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: ACCEL injectors
I have a set of the yellow first style accel injectors with a little over 10,000 miles(2.5 years) on them without any problems.I bought them before I knew about there reported problems.I was thinking of going with there new style silver 24# injectors until I saw the prices you posted at fuelinjection.com.I bought mine just before they changed to the new style,not sure if that explains why i`ve had no problems.
92-Formula
Dec 12, 2015 10:34 PM
85 Jimmy
Sep 30, 2015 07:56 AM
BAMiller
Sep 14, 2015 06:38 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
