how much less do aluminum heads weigh?
Old Dec 12, 2001 | 09:03 PM
breathment's Avatar
how much less would say Vett L98 aluminum heads weigh over stock iron heads?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake, and an Energy Suspension Poly trans mount that is worse then the broken rubber tranny mount
http://www.geocities.com/david_angel_16
Old Dec 12, 2001 | 09:40 PM
rezinn's Avatar
Im just going to take a guess at this since I never weighed mine, but I'd say about 10 pounds less on each. I just remember carrying them around, and there was a quite a bit of difference.
Old Dec 12, 2001 | 10:16 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
A lot. I had to use both hands to move my Iron Eagles around. All the aluminum heads I have played with I could lift with one hand or even a few fingers. those are all aftermarket heads though, not OEM aluminum's.
Old Dec 12, 2001 | 10:26 PM
Guest
Guest
Posts: n/a
The stock heads are about 45# a piece. The AL's weigh 16-19# depending on who's scale you want to trust. Mine were 16# assembled (according to my trusty scale). Thats a total of 58 less. Yea, they are quite light.
Most AL heads weigh more, like 25-30 each.
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
bdads
Aug 24, 2015 06:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
