Why was HP increased from 88 to 89?
Old Dec 11, 2001 | 02:39 PM
JR4444's Avatar
What was the difference between the 88 and 89 L98 engines? The 89 had like 15 more HP, was it because of a bigger cam? Larger Intake? Better Exhaust? ect...
88 L98 230
89 L98 245 (I think)
88 Formula 350 WS6
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, ZZ4 cam, 24# Motorsport Injectors, Larger Gutted Mass Sensor, Homemade Cold Air induction, PROM by performance resources, MSD 6a box, MSD Distributor, Accel SuperCoil, Taylor 8mm wires, TB Bypass, B&M shift Kit, 160* Thermostat, Flowmaster Muffler
Headers in the mail soon to be installed
Old Dec 12, 2001 | 01:20 AM
JR4444's Avatar
ttt
Old Dec 12, 2001 | 02:38 AM
FormulaGod's Avatar
Two cats on the 89. More power.
"Restore decency in America. Ban rice!!"
Old Dec 12, 2001 | 11:54 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by FormulaGod:
</font>
not all 89's got the dual cat. I think the cam was different
*89 Trans Am GTA
*Moderator at www.transamgta.com
To hell with the GM vs Ford war. We must unite, as brothers to fight the plague that is overtaking the world...RICE
Tony
Old Dec 12, 2001 | 12:31 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
According to the information that I have (summarized in <A REF="https://www.thirdgen.org/messgboard/Forum12/HTML/005622.html">this posting</A>) the '88 and '89 cams are the same.
Old Dec 12, 2001 | 01:47 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Between 88 and 89 they did a lot of changes for example they switched to serpentine belts, started using VATS, and got rid of the cold start injector. I know this does not answer your question but they made a lot of modifications between those 2 years. I think they made a few minor tweaks to the engine and computer, which could have done it.
1989 Iroc-Z 5.7 350, Blue, T-Tops
Lightly Moded:
Edelbrock Headers, Rebuilt B&M 700R-4 Tranny, Higher Stall Torque Converter, Airfoil, 3.4 w\posi, K&N's, Ported & Polished Plenum
-- Blue LED Bakelite Dash & Climate Control
- I am just some 17 Year old spending every dollar I make on my car.
Old Dec 12, 2001 | 02:24 PM
CamaroRS's Avatar
Actually, 88 was the first year of the serpentine belt system. The extra horse power and torque was the result of the G92 option if the car came equipped with it (only could be gotten with a 5.7 TPI motor (B2L) or 5.0 TPI motor (LB9) with 5 speed (MM5) manual). The G92 option included the N10 performance exhaust system (dual catalytic converters) which increased power output by 13%. The cam was the same for all 350s in 1988 and 1989.
[This message has been edited by CamaroRS (edited December 12, 2001).]
Old Dec 12, 2001 | 07:06 PM
Little GTA's Avatar
Dual cats
89 TransAmGTA L98/Auto Grey/Grey T-Tops
Best 1/8th: 9.02 @ 76
89 TransAmGTA LB9/5speed FlameRed/GreyLeather Hard Top
Old Dec 13, 2001 | 12:03 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I agree with those that say "dual cats" Both 88 and 89 engines are EXACTLY the same as far as power, belt systems, etc. Maybe slightly different ECM cals.
Both L98's put out 230HP@4800 RPM and 330HP@3200 FT/LBS ... HOWEVER, in 1989 the G92 "performance" option was available, boosting the L98 to 240HP@4400 RPM and 345@3200 FT/LBS (due to the dual cat G92 option).
Elephantismo
Feb 13, 2019 12:51 AM
gord327
Oct 3, 2015 01:25 PM
hartsmike
Oct 2, 2015 07:11 AM
WhteRbt
Sep 21, 2015 09:48 AM
