do you think this is a good combination?
Old Jun 25, 2008 | 11:46 PM
72chevelleTPI's Avatar
I know its not for a Camaro, but you guys know the TPI setup really well. I have done a few TPI swaps before but nothing majorly modified. This setup will be going into a 72 Chevelle with a built 700r4 behind it and 4.11/posi rear end. Do you guys think its a good combination? Any changes you would do? What kind of numbers do you think it will put down?
TPI unit out of an 86 so its MAF with the 9th injector
350 bored .060 over
Should be around 11.5-1 compression ratio
Melling High volume oil pump
Comp Cams 08-503-08 cam
Cloyes double roller timing chain
Comp Cams retro-fit hydraulic roller lifters
Edelbrock Victor JR 70cc aluminum heads
Comp Cams 1.6 ratio rockers with 7/16 studs
Scat forged crank
TRW-L2304F60 pistons
Ported upper TPI plenum
SLP high flow runners
Edelbrock Lower TPI base
30lb injectors
BBK Adj. fuel pressure regulator
TPIS 58mm Throttle body
Granatelli adj. MAF
MSD 6al
MSD Small cap Distributor and remote blaster coil
No EGR
Long tube headers
Westers custom tune PROM
Old Jun 26, 2008 | 07:35 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
Re: do you think this is a good combination?
that sounds like a really good idea
something tells me that you allready know that
Old Jun 26, 2008 | 10:39 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
`I think a 58mm throttle body is going to be a little much. A 52 will flow enough(900 CFM as compared to 1100 with the 58) As for boring the motor .060 over, I my mind that may be a little to much. other than that pretty stellar setup
Old Jun 27, 2008 | 01:55 PM
But it shouldn't hurt the performance with the 58mm TB right? They are about the same price so I figure why not just get the bigger one and if I ever need it, its there.
The block I am using is already .060 over. We had it in a 69 chevelle that was carburated that ran 10 sec all motor. Only has about 5 passes on the strip on it.
Old Jun 27, 2008 | 04:33 PM
Abubaca's Avatar
You won't have any catastrophic problems with the 58mm TB. There's a lot of debate about whether or not a 52mm will actually HURT performance just a smidge on stock or very mild builds, but for what you're doing, I can't see ever noticing ANY difference between the two, 52 or 58.
......4.11 gears seem pretty deep though....
colton_carlson
Mar 8, 2019 12:21 PM
MantyZ28
Jan 18, 2016 08:30 AM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
cRoe4
Aug 7, 2015 08:46 PM
