I know asked before, but Valve cover Part # for full 1.6 rockers
Old Dec 10, 2001 | 01:39 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I need valve covers for my AFR headed 357 with full 1.6 rockers. Any part numbers of covers under $200.00
Chris
1986 Iroc 355 TPI coming soon
1985 Z28/5-speed Daily Driver
Old Dec 10, 2001 | 04:02 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
ttt
Old Dec 11, 2001 | 12:34 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
Hey,
What brand are you running?
White '88 RS (originally 2.8)
Previous engine-350, .040 over, vette alum. L98s, stock tpi, stock 305 injectors & chip. TES headers & edelbrock cat back. 3.73 gears, 700r4.
Best with 2.8-17.4@77mph
Best with 305-15.0@93mph
Best with 357-13.7@101mph
on a 2.050 60 ft.
(Damn the 2.8!)
New Setup:
4 bolt 357 (10.2:1), AFR 190s (fully cnc ported), LT4 Hot cam (1.6 RRs), Ported SuperRam (upper&lower), Ed Wright custom chip, 24# Accel injectors, Yank 3200 lock-up TC, 3.27 9 bolt rear, some traction! Hoping to see some 12s.
Old Dec 11, 2001 | 07:27 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
I'm curious on this question as well.
Old Dec 12, 2001 | 09:40 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Well, right now the motor is on the stand with no valve covers right now. Is that what you were asking?? btw they are centerbolt. anyone have pictures??
Chris
[This message has been edited by NufNuffZ28 (edited December 12, 2001).]
Old Dec 12, 2001 | 11:08 AM
Car: Damn
Engine: This
No i meant what brand are the roller rockers that you using?
Old Dec 12, 2001 | 12:52 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I'm using comp cams 1.6:1 full rollers with L98 aluminum heads and the stock unmodified covers. Maybe I'm lucky...
I ordered my AFRs for permiter covers so I could run a stud girdle. Any recommendations for perimeter covers that will fit a stud girdle that won't break the bank?
Old Dec 12, 2001 | 02:02 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I have the Crane gold 1.6
my stock ones are perimeter, but some aftermarket short ones did not work. Will stock centerbolts fit? I think they would be too short. I have 1.6 rr on my g-friends 94 Z and her stock covers fit fine. 87 Fake Iroc. You are running stock covers on your full 1.6's?? What brand?
Chris
Old Dec 13, 2001 | 05:37 PM
Car: Damn
Engine: This
I am using Harland Sharp 1.6 full roller units. They are for 3/8 stud.
With my last heads (vette aluminum L98s) the stock centerbolt covers fit with no arm clearance problems. The only thing that was tight was that when the valve cover was bolted down it would slightly hit the top of the poly-locks- no biggie since they don't move.
On my new engine I am using AFR 190s with hopefully the stock centerbolt covers, i havn't set valve lash yet so i don't know how the clearance is with those heads. My guess is it would be the same if AFR uses the same lip height for the cover rail.
I'm guessing your heads are dual pattern if you are switching from perimeter to centerbolt. right?
[This message has been edited by '87FAKE-IROC-Z (edited December 13, 2001).]
Old Dec 18, 2001 | 04:30 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
naw. They are just centerbolt, but the engine is out of an 1989 truck so it originally had centerbolt anyway. Oh yea I forgot my rockers are Comp cam, not Crane
Chris
midge54
Dec 27, 2019 04:14 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
