switching cam and 1.6 rockers... need new push rods?
Old Jun 28, 2008 | 11:53 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Im changing my 87 305 peanut cam to an 89 350 cam and installing 1.6 roller tip rocker arms... will the stock length pushrods work with this application.... also Im switching to 601 heads milled .030. thanks
Old Jun 28, 2008 | 02:05 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Re: switching cam and 1.6 rockers... need new push rods?
Should be fine on both mods
Actually milling the heads affects pushrod length
more than the .1 you pick up in the arm.
Roller center of valve stem at mid lift is ideal, but as
long as close, no problem.
Later
Old Jun 28, 2008 | 02:07 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
thanks dude..
Reborn756
Sep 4, 2015 03:42 AM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 9, 2015 01:15 PM
