another valve cover question
ok, I was told by my mechanic that the only rockers I can use are the 1.5 Crane gold roller rockers with my stock centerbolt valve covers. what I am wondering is if I can use less expensive rockers with taller valve covers for less than the price of the 299 dollar rockers alone. . any suggestions?? thanx
1987 Pontiac Firebird Formula 350
1 of 2,384 made, Black with Silver decals
383 c.i. TPI, my "little beast"
"FORD, where quality is job number one, and flipping the explorer back over is job numner two, I supose that would make putting out the fire job number three?"
I was raised a FORD guy, but I def. couldn't resist that one.
I wanna just use the 1.5, cuz it is all I need, but my mechanic was saying that the only ones that fit are the comp cams magnum rockers and the crane golds, I don't know if it has to do with clearance or the fact that they are center bolt valve covers. . I just kow that summit sells rockers that sound exactly like the crane ones for half the price and that valve covers aren't all that expensive, I am just wondering what road you suggest I take
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
I'm using comp cams 1.6:1 full aluminum RRs under my stock covers with L98 aluminum heads. No problems; didn't even have to trim the supports.
I'm Crane 1.6's with the stock valve covers and it works great. I read that you're supposed to grind away some of the valve cover supports but I wasn't sure what I was supposed to grind, so I just ground everything that was near the rockers. They also go on a little easier. If you're going to get 1.5's at least get the 1.6's for the same price.
how do I know if I have aluminum heads or not, mine is an 87 350 TPI, well it was a 350. how do I tell?
U have cast iron heads, not aluminum, although u do have the "Corvette" engine... albeit with the iron heads... btw the aluminum heads still have the same intake and exhaust size valves, but I believe the compression is slightly higher. U have 64cc combustion chambers, the Corvette may have 60, I'm not sure.
Jethro
1987 IROC Z 13.92 and 1.92 60' street tires stock engine
Jethro
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
