88 Wiring Harness on a 89 TPI Setup?
Old Jul 1, 2008 | 02:17 PM
camaro87-alex's Avatar
Car: 1987 Chevrolet Camaro SC
Just have a simple question about TPI wiring harness...
I have bought a complete TPI setup from a 89 Camaro.
I have also found a TPI wiring harnes (used) from a 88 Camaro that has a cold start injector. My TPI setup has not this injector since it is from 89.
Will this wiring harness still fit my setup?..Is it just the PROM I need to change on the ECM, to specific 89 model?...
Old Jul 1, 2008 | 03:17 PM
Russ-So Cal's Avatar
Re: 88 Wiring Harness on a 89 TPI Setup?
Do you have a Helms manual for your car? The only way to be sure if it will work is to check the wire/pin relationship between the 2 cars or between your car and the harness on the ecm plugs. G.M. has a tendency to change the pins around even when using the same plugs for the various ecms depending on what ecm and what system is used.
My T/A was originally a Carbureted car. We converted it to speed density and used a tbi harness, but we had to go through and move the wires around to get the correct wires in the right pins for the tpi as well as install wires for sensors that the tbi didn't use.
Old Jul 1, 2008 | 03:46 PM
Sorry, but I don't have this manual...And I noticed that you have written to me on my fuel line question. Everything I buy is from Ebay so I don't have any Camaro to get parts from. I only find listed items on Ebay. I live in Norway so it is VERY HARD to find a junk yard car..I can almost guarantee here is no Junk yard car at all..Everybody want to restore them if they are being crashed...
I think this wiring harness would work on my car. Because I see that tpiparts.net produces this plug kit for the Cold start Injector and that seems to me that, every harness from 85-89 could be used only you got the right PROM for the year, and setup.
Old Jul 5, 2008 | 09:20 AM
87SSTPI's Avatar
Car: 1987 Monte Carlo SS
Engine: Vortec headed 350
Transmission: '89 WC T5
I'm curious about this also, someone on here surely has to be able to answer this.......BUMP
Old Jul 5, 2008 | 10:30 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
reprogram the prom and cut all the 9th injector out
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
