Engine Idles - Ac
Old Jul 14, 2008 | 12:16 AM
Jokerslye's Avatar
Engine Idles - Ac
Anyone know why when I Start the car It will start up at around 10rpm then If I let It sit it will drop down to 7-8 then 4-5 and chug and fight and then work itself up but then eventually stall ? I mean If I am at a stop light I have to feather the pedal or It stalls.
Also anyone know anything about AC? I bought a new AC belt and put 3 cans to recharge it but I can't get anything to come out of the vents ? I can see the compressor turns on and works fine ? Any Ideas ?
You think its the TPS sensor for the Idle ? Because I took the TPS Sensor out and It went all the way up to 15rpms but never died ?
Old Jul 15, 2008 | 01:55 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
Re: Engine Idles - Ac
a/c problem is more than likely the blower motor or a blower motor relay. mechanic should have checked the vents before charging the a/c. blower motor is around $20 and takes 10 minutes to install.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
