TPI runner question
TPI runner question
I have some runners that have some scratches on the inside of the ports. Is there a tool or attachment for the drill I can use to clean up/polish the insides of the ports? I dont have anything that flexible that will work.
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: TPI runner question
..... theres a ball kit that pops out dents and I would assume smooths out the interior walls. If your just looking to pop out dents then just fill with water and throw in the freezer.
I did seach cant find anything. I searched "dent removal ball" , " Runner dent removal" and several other things. These runners are not dented much mainly want to clean the inside.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Someone suggested to me to glue sandpaper to the ac pipe wrap foam. Then run it up n down the holes.
Since your on stock runners, start midgrade paper, and work to finer paper each time. Will take some time, but should do what you want.
That sounds like a good idea if I can find some to fit well.
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Yes I have several sets I have fixed with balling and freezing with water and using a propaine torch to heat the dents one frozen then re freeze.
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Easwood Company sells a cylinder head porting kit. It consists of sanding rolls of various grits and a 6 inch long rod that the sanding rolls attach to. I have used it to sand the id of the runners to get rid of scratches. Aother option is go to MSC Industrial supply, www.msc.com, that have ball hones of various sizes. I have also used that to sand the id of the runners.
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Wouldnt spend any money on it unless it really really bugs you scratches wont affect how it runs.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Scratches aren't going to have any effect on the airflow of your runners.
Sanjay
Aug 12, 2015 03:41 PM
