TPI SENSOR LOCATIONS?????
Old Aug 7, 2008 | 08:34 PM
ParkerTPIz's Avatar
Ok so im finishing up an l98 tpi setup into my 90 lo3 tbi car..
the drivetrain and harness are out of an 87 gta with the MAF TPI setup.
i just want to varify what these are and where these sensors go...
I NEED HELP WITH PLACEMENT ON THE BELOW SENSORS. (PASS HEAD, PASS SIDE BLOCK, DRIVER HEAD, DRIVER BLOCK...ETC
i know all of these below except one (the last one on the right)
From Left to right
1. Oil pressure
2. knock sensor
3. fan turn on switch
4. fan turn on sender switch ( i think)
5. coolant temp sensor
6. I HAVE NO CLUE
THANKS A TON GUYS ALL AND ANY HELP IS MUCH APPRECIATED.
Old Aug 8, 2008 | 08:35 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: TPI SENSOR LOCATIONS?????
1. oil press. sending unit, goes right above oil filter.2 knock sensor, pass. side engine block in front of starter. 3.temp sensor fan turn on, pass. side head between back 2 plugs.4 not sure, maybe coolant temp sensor , front of intake. 5. sending unit for temp. gauge, driver side head between first 2 plugs.6.same here. hope this is correct,later jimmy
Old Aug 8, 2008 | 11:34 PM
ParkerTPIz's Avatar
ok cool thanks, thats pretty much exactly what i thought. i just cant figure out, for sure, what number 6 is at all
Old Aug 9, 2008 | 01:30 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
#6 appears to be the cold start injector switch. you don't need it though if you go with an 89 MAF PROM, or a later speed density setup. also, i think the oil pressure sender is just the switch for the fuel pump relay. if it has 3 wires, its a pressure sender, otherwise, you will need a seperate sender for the oil pressure gauge.
Old Aug 9, 2008 | 04:59 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Your first one is definitely an oil pressure switch not to be confused with oil gauge sender.
3 & 4 look like engine temp gauge senders, or light switches.
The last one is a coolant type sensor, but not what would I expect for the ECM.
What you should have for an 88 or older TPI[
  1. oil pressure switch for fuel pump (if 3-wire, 3rd wire is for oil light switch, uses sensor body for ground)
    if you use teflon sealer, or thread locker you must check for zero ohms from sensor body to engine ground especially on single wire sensors.
  2. oil gauge pressure sender single wire not connected to ECM - left side of diizzy.
  3. knock sensor - right side center above oil pan rail
  4. over-temp, or heavy duty fan relay temp switch - right side near #6 & #8 plugs
    Note 3 & 4 uses the same type of connector
  5. cold start temp switch front of intake uses fuel injector type connector
  6. coolant temp sensor for ECM - 2-wire connector - front of intake
  7. engine temp sender - left side near #1 & #3 plugs
I can only upload 3 pictures
from left to right: CTS, oil gauge, engine temp gauge.
Attached Thumbnails TPI SENSOR LOCATIONS?????-cts.jpg   TPI SENSOR LOCATIONS?????-os.jpg   TPI SENSOR LOCATIONS?????-engine-temp.jpg
Caspar
Jun 19, 2016 11:19 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
Rustyweb7
Aug 9, 2015 03:05 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
