TPI to LT! intake... now smokes :(
Old Aug 11, 2008 | 10:07 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
ok so basically i just replaced my tpi intake system w/ a lt1 intake manifold that i have been modifyin for a few weeks now, got the bolt holes right, dizzy hole where it goes, blocked off the egr valve and the other little one and drilled holes for water.
Now car runs like a champ and pulls hard BUT at rpms of over 4k it smokes quite alot. that had never happened w/ the tpi before and its drivin me insane cuz i cant figure it out.
my setup is a 350 block flat tops, mild cam ported 64cc heads 1.6 R.A. lt1 injectors, 44psi of fuel pressure and walbro 255lph fuel pump
i have already replaced the intake gaskets twice thinkin that was the problem, second time i made sure everythin was perfect and used alot of sylicone.
what could be wrong??
Old Aug 12, 2008 | 11:44 AM
Re: TPI to LT! intake... now smokes :(
any ideas or thoughts??
Old Aug 12, 2008 | 12:31 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
whats the color of the smoke?
Old Aug 13, 2008 | 07:19 AM
its like light blue.
At first i thought it was because my fuel pressure was too high so i lowered it to 42psi and its still smoking. the injectors are the same ive had on for the past 6months and they are being controlled by a custom burnt prom.
i also thought it could have been that i plugged a vacum hose into the wrong nipple or something so it was suckin in oil but then i got rid of all the unessesary vacum plugs so the only ones i'm using are one for the brake booster and one for the AFPR.
Last edited by noboostnogo; Aug 13, 2008 at 07:24 AM. Reason: Automerged Doublepost
Old Aug 13, 2008 | 11:19 AM
Gunner823's Avatar
Engine: L98 355
Axle/Gears: 3.70
Light blue smoke is oil smoke.
diana227vegas
Jul 8, 2016 12:27 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
