need help maf/esc failure
Old Aug 17, 2008 | 03:58 PM
tuned-z's Avatar
need help, have had a re-occuring 33-maf code with very little or no running problems. now pulling out of storage, engine sputters badly will not accerlerate, and store code: 33-maf 32-egr 43-esc 42-est. could anyone give me a few pointers please. i do have some experience in tpi diagnostics, but i am in a crunch now because our grand rapids metro cruise is coming up in a few days.
Old Aug 17, 2008 | 04:03 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: need help maf/esc failure
While it's sputtering disconnect the 4-pin MAF connector. If it clears up....replace the MAF.
Old Aug 17, 2008 | 04:05 PM
tuned-z's Avatar
will this also cause ecs est egr codes or are there likely other problems?
Old Aug 17, 2008 | 04:15 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Some problems have the snowball effect. I'm not saying that's happening in your case but you did mention that you've had the MAF code on a regular basis. That's your intake. All kinds of things can get messed up if your intake charge is hosed.
Old Aug 17, 2008 | 04:30 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Tuned-Z Where are you located? I live in the ada/cascade area.
And for your 3 codes-could be a number of things
Dirty maf, maf is bad, possibe maf relay, Egr is stuck open-will run like crap if its stuck open, and your esc could be bad. I just picked up a new esc module for my car at napa for $60 the other day.
Old Aug 17, 2008 | 05:07 PM
tuned-z's Avatar
grand rapids, running in metro cruise, white iroc w/gold wheels, see you there?
Old Aug 17, 2008 | 05:16 PM
tuned-z's Avatar
i re-installed the original maf (factory original) seems to run fine now and accelerates good. previously i have been having re-occuring maf problem, had made all kinds of tests per manuals. then started throwing parts at it: ecm w/updated prom, all-3 relays and pigtails, new maf sensor (re-man from gm dealer). strange thing is that it allways ran good when code was stored, they usually run very bad with code 33. i hope the esc codes were just set in error becuse the timing could not advance when i accelerated, but only time will tell.
Old Aug 17, 2008 | 08:26 PM
I will be at Berger Chevy. I am the only 86 Blue Iroc-Z with shaved door handles in the Camaro Club.
Grant2k
Apr 4, 2016 08:21 AM
F-body-fan
Nov 4, 2015 06:13 AM
Fanatic1074
Oct 2, 2015 03:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
ban1one
Aftermarket Vendor Review
Sep 15, 2015 10:10 PM
