90mm Throttle Body Too big?
Old Aug 16, 2008 | 12:11 PM
1bdbrd's Avatar
Car: 1991 Trans Am
I just got my new 90mm throttle body in the mail the other day and I was wondering what it was going to do performance wise to my car. Now let me say that I know its not going to pick up crazy power or anything stupid like that. I actually bought it because the new intake I am going to use requires it. As soon as a few parts sell I will be purchasing a pair of Dart Pro 1 heads and more than likely an XFI280 cam kit for the stock bottom end.
Will the 90mm tb hurt performance at all? If it stays the same then I am fine with that, I just don't want a major loss for some reason.
Old Aug 17, 2008 | 12:24 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 90mm Throttle Body Too big?
What intake are you using?? The Ram Jet? Every TPI intake I know about uses a stock twin 48mm, and the upgrades are twin 52mm and twin 58mm. LS1's can use 90mm and the Ram Jet does too.
Old Aug 17, 2008 | 10:10 PM
1bdbrd's Avatar
Car: 1991 Trans Am
I'm planning to use the new Edelbrock Pro Flo XT intake when it finally comes out.
Old Aug 17, 2008 | 10:26 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Simple answer is no.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
