Cylinder Head Angle?????
Old Aug 20, 2008 | 11:19 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
When I bought my replacement heads for my 305 TPI I asked if I could put 194 heads on it and the man said "no the angle on tuned port heads were different and the intake manifold wouldnt bolt up cause it was at a different angle". I was always under the impression that all SBC heads were 23* heads and you could pretty much plop TPI on any small block with the proper ECM. Can anybody verify this? Or any info? Thanks.
Old Aug 21, 2008 | 06:59 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Re: Cylinder Head Angle?????
It's my understanding that all Gen I SBC have to same intake manifold angle and bolt pattern until the Vortec heads came along.
Old Aug 21, 2008 | 07:45 AM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
55-85 are all the same intake bolt pattern. The intake bolts are perpendicular to the head. 86-95 the 4 center bolts are at like a 60* angle to the head, and Vortec heads 96-02 only have 8 intake bolts total and they also go in at an angle to the head. All stock small block chevys had 23* heads just the bolt patterns are different. U can use an old style head you just have to modify you intake. Elongate the 4 center holes, some might not recommend this tho. $.02
Seth
Old Aug 21, 2008 | 08:05 AM
19 z28 92's Avatar
Car: 1992 z28
Engine: carb 355
Transmission: wc T-5
Axle/Gears: 4.11 posi 10 bolt
I'm pretty sure the split is 86-down for the old style and 87-up for new style
Old Aug 21, 2008 | 11:36 AM
Car: '89 IROC-Z
Engine: LSx
So its just the bolt pattern. So you couldnt just throw a TPI intake manifold on any set of small block heads. If I were to buy "aftermarket" heads how would I go about getting the correct bolt pattern? Thanks.
Old Aug 21, 2008 | 03:13 PM
Bigseth's Avatar
Yeah I thought it was 86 or 87 but I was still half asleep when I typed that. You can use a 85-86 TPI base or just elongate the middle holes on a 87 up base.
Seth
Old Aug 21, 2008 | 06:54 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Well I learned something today.
Old Aug 21, 2008 | 09:58 PM
Car: '89 IROC-Z
Engine: LSx
Well thats good I have an 85 or 86 TPI in my 89 IROC. So If I ever decide to change to block I can use what I have. Thanks for all the info.
James.
Chuck84TA
Jul 15, 2016 09:05 PM
CRFred
Feb 7, 2016 11:39 PM
gixxer92
Sep 1, 2015 04:32 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
