305 TPI issue
Old Aug 21, 2008 | 01:26 AM
extrat162's Avatar
Car: 1989 IROC-Z
Transmission: 5 Speed
305 TPI issue
I've got a 305 TPI and when the engine is cold I can rev it to the redline and it runs very strong. Once the engine warms up I cant get it to go above 3500 RPM's and it occasionally sounds like it's backfiring through the intake. Once I let off the gas after it starts doing this it basically dies. Any ideas about what it might be?
Old Aug 21, 2008 | 09:46 AM
Steve89GTA's Avatar
Re: 305 TPI issue
Is it hard to start once warm? Could be ignition coil
Old Aug 21, 2008 | 10:28 AM
extrat162's Avatar
Car: 1989 IROC-Z
Re: 305 TPI issue
I bought a new Ignition Control Module and a new Ignition Coil and put them on. No change... same issue.
Old Aug 21, 2008 | 08:19 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 305 TPI issue
I would be be thinking MAF sensor. When it's warm it's in closed loop.
Old Aug 21, 2008 | 10:28 PM
extrat162's Avatar
Car: 1989 IROC-Z
Re: 305 TPI issue
What is "closed loop"? I'm new to the whole TPI scene. Also I just noticed that the fans don't come on, even after it has warmed up. Fan relay maybe but I don't know where it's located.
Old Aug 22, 2008 | 05:00 PM
extrat162's Avatar
Car: 1989 IROC-Z
Re: 305 TPI issue
Anymore ideas.... Anyone?
Old Aug 22, 2008 | 06:12 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Re: 305 TPI issue
Fan relays are located at the battery tray in mne.
Is this a car you bought and had the running problems or did it once run fine and has just started being an issue? You can try unplugging the MAF and see how it runs.
Old Aug 22, 2008 | 09:13 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: 305 TPI issue
There's more than just one coil type in all cars that can affect hoe it runs; injector, relay, alternator, fuel pump.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
