Here's goes the crazy 305 TPI Build
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Re: Here's goes the crazy 305 TPI Build
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Dude my hats off to you for going this route!
I will be following this thread for sure. I'm sure you may know this already, or a member has already posted it. But the TPI was originally designed for the 305. When GM came out with the 350 TPI, they just took the 305 TPI and put it on a 350. If I recall they just changed the injector size, but everything else on the top end stayed the same.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Axle/Gears: factory 9 bolt with 3.45 gears
can't wait to see what that thing's gonna do! Do you think you'll be able to take a video of a 0-60 or 1/4 mile run? And I forgot to mention... I love how it looks stock with the exception with the braided fuel/PS lines... but those still fit in perfectly. Looks like it just rolled off the assembly line.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
I was bleeding the brake system tonight. Man, there was so many leaks. Was trying my best to not let any brake fluid get on the paint. Hard to avoid. I need to get in touch with Wilwood, it's a nightmare to bleed their four piston calipers. Crap design.
Car: 1988 IROC-Z28
Yes, I sure have heard and agreed the GM designed the TPI around the 305. Thanks for the encouragement. The ECM is programmed a bit differently as well for the 350, but who's counting.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
I actually spoke with Ed about a year ago about my build. I will wait until I get the engine up and running...work out as many bugs as I can...and then install the ATI procharger. Reason being... i don't want to wait to start the engine when everything is done because that will just add to the complication. anyway, i could have just said i'm working with Ed and he has a program that fits my build once I'm ready. He said he programed a chip for someone that has a corvette with the same cam, and exhaust mods. He will use that program and tweak it some for the differences in fuel metering and possibly some other parameters. I'll put up some more pics once my headers, y-pipe, intermediate pipe, and tail pipes are ready.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Well, I got everything back from the blaster. They look great but hit a road block because the donut gaskets for the headers didn't fit. I ordered them from Summit, they are the #6961 Edelbrock gaskets but they are too small! I wonder if I can get the right size from a local auto parts store.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Here are a few new pics... getting closer....! Headers, ypipe, cat converter, heat sheild, intermediate pipe, radiator, hoses, and a bunch of other stuff that is hard to see are installed.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Car: Faster
Engine: Than
Transmission: You!
Just a few tips....
First, you should a dremel tool with reinforced cut-off wheels to make the lover cuts, then use the small dremel sanding rolls to round the corners of the new openings. That would make the vents look cleaner. Then mask off the bottom of hood and on top arround the louver part of hood and paint that area a satin black before installing the louver. Next, you have your driver side valve cover backwards, rotate it 180* The oil fill cap should be closer to the front of the car where it's more accessible.
Nice build thusfar, keep up the good work!
Engine: LB9
WOW your car is so clean! Even keeping a rag on top of the jackstand! Good for you. And I meant to ask, where in CT are you? I'm from Plainville.
Car: 1988 IROC Convertible
This is a really impressive build. I want to stick with my 305 too just because. So, I actually have a question for 305sbc. My mods are:
Edelbrock base intake
Edelbrock runners
Matched plenum
Summit headers and y pipe
Hi flow cat and 3" Flowmaster cat back
My next step is headwork. Your threads on L98 heads and or LS1 valves on 416 heads are very interesting but I'm wondering what you would suggest best fits my current mods. After that I'll match a cam. My purposes for this car are mostly cruising but it might see some circuit track time. Any suggestions will be greatly appreciated. Thanks.
Edelbrock runners
Matched plenum
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Just a few tips....
Car: 1988 Firebird Formula
Engine: 5.7 TPI
Axle/Gears: 3.27 posi 9 bolt
Very nice work being done here. Looks like you have been working on this car for more than a year - shows commitment! I'm very interested in your results - my 88 came with a complete rebuilt 305 when I got it and it had only run for 1 month before getting into storage for 2 years. I've got it running sweet and I'm just getting the body work done now - looking to drive it this summer - but this winter will be looking to add some ponies!
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Cool to hear about your rebuilt 88, have fun with it.
Car: 86 Camaro
I've been watching your build as well and am enjoying it too. It looks like you have spent some serious time and dough. I'm building a 305 TPI right now too, probably for my 86 Camaro. Is your first start on a stock chip?
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Yes, I'm using the stock chip and it is now running pretty well. Just adjusted the base timing today.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
UPDATE:
Today I got the engine running nicely. It turned out to be a vacuum leak. I did the TB Bypass but two of the hose inlets on the pass side were left unplugged. I thought they were just coolant passages. I taped them and the engine smoothed out. I'm very happy to say I was able to set the base timing (by unplugging the EST wire) 6 degrees BTDC. I've got some exhaust leaks (at the slip joints) but that's becuase I used crappy T-bolt clamps. I ordered band clamps and that should take care of it. I need to post a vid of it running. I was so surprised almost everything electronic works. Even with this much larger cam to check engine light does not come on. The next step is to get the exhaust taken care of and the front and rear brakes on... stay tuned....
Car: 86 Camaro
Don't forget to check your minimum air rate on the throttle body and the tps.
Have you let it go into closed loop?
And definetly try and get a video up that would be cool.
Car: 1989 gta-1995 formula
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3-45
Just wondering i have a set of 305 vortec truck heads would they be much of an improvement to my lb9, thanks for any info on these never heard much on these heads.
Engine: 305 tpi
Axle/Gears: 3-45
[quote=Hutts;4542011]Just wondering i have a set of 305 vortec truck heads would they be much of an improvement to my lb9, thanks for any info on these never heard much on these heads,any body tried them.
wow, this makes me get goosbumbs... I love the litlle 305 tpi!!! I have just recently did some work on my 305, but it may not be a good build after all. After a ton of researching and reading articles, I came to find out that the place that i bought my heads from sent me the 58 cc 2.02 intake 1.6 exhuast heads...... and I also put a 1.6 roller rockers on it too. I did run the engine and I know that it is running well but not to its full potential!!
I just wanted to say that i love what you did with this car! great job!
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
I have a stock cam in it. basicly the stock heads were junk so I just replaced them and the lower intake manifold. I have been reading and told from a few people that they would not work but they do.
here is a sample without headers, just a short clip!
http://www.youtube.com/watch?v=-VKTEQtP3Ig
Last edited by thirdgenbird89; May 17, 2010 at 02:55 PM. Reason: wanted to add something to it
Car: 1985 iroc z
Engine: 350 .30 over
Transmission: t-5
Axle/Gears: told aftermarket moser 3.73 posi?
awesome car can wait to see it finished and watch a vid or two maybe?
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Yes, I will get a vid up.
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Good question. I'm not familiar enough with the vortec heads. I don't know if your 305 truck heads are any different than the vortec heads you can get from Scoggin Dickey or others. I know the vortec heads that come standard on many of the crate engines flow quite a bit more than stock 305 Camaro heads and you may have an issue with the size of the valves running into the 305's cylinder wall..or loosing a bit or torque on the low end, due to the Vortec's increased intake and exhaust runners. Do some searching on the Vortec heads on the 305
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Gauge install...fun too
oil temp, fuel pressure, and boost gauge (in advance for when the D1 is ready)
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
Okay, here's a vid of the engine being started up. It's a real short vid because I don't have a memory card for my camera yet... but here it is on you tube...
http://www.youtube.com/watch?v=EcriEngvdtY
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
I will get the memory card and show more or what has been done.. stay tuned (punn intended)
Car: 1987 IrocZ
Engine: lb9
Transmission: 5 spd
if you only knew how many hours i spent under that car.. you may cover you stands too! ha, it's crazy... i don't think i would do it again.
