anyway to fix a throttle body???
Old Aug 31, 2008 | 08:05 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
i have a stock throttle body, it wont close all the way shut, so it idle high. the spring is very old, anything i do to fix this? dont realy have the cash 4 a new one right now
Old Aug 31, 2008 | 08:52 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: anyway to fix a throttle body???
Have you tried cleaning it? It's usually gum that makes them stick.
Old Aug 31, 2008 | 08:59 PM
jayk2k3's Avatar
Car: 85 camaro z28
yup, ive clean the inside of the throttle body couple of time. the spring is weak. can u just buy the spring?
Old Aug 31, 2008 | 10:53 PM
jv9999's Avatar
Engine: 5.7L/350
You probably could have once, I don't know about now. Have you tried a little oil on the throttle shaft? As a temporary solution you jerry-rig a carb return spring to pull it back.
Old Sep 1, 2008 | 12:50 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The spring should be OK, unless it's been removed and not wound properly on installation.
You might try using a feeler gauge to measure the clearance of the idle screw, then back it out to allow the plates to completely close after loosening the plate screws. Now open & close the throttle a couple of times to allow the plates to reset to center, then while holding it closed tighten the plate screws. Set the idle screw back to where it was and see if it works any better.
Old Sep 2, 2008 | 07:20 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
If the shaft/bores are worn enough it will cause a sticking problem.
Check for any up/down or side to side movement.
Old Sep 2, 2008 | 08:24 PM
jayk2k3's Avatar
Car: 85 camaro z28
if i back down the idle screw, the plate stays in the same position, untill i push it back. i was goin to try to jerry-rig a carb return spring to pull it back, but i thought it would make the pedal to hard. i gave up. Decided to eat it, and upgrade to a 52mm throttle body. do throttle cable ever stick (binding up), like e-brake cable do???
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
