How to tell if o2 sensors bad?
Old Sep 4, 2008 | 03:28 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Im pretty sure my o2 sensors bad because i just replaced the plugs twice? i think and their bad again, so im pretty sure its my o2 sensor. Is there any other way to tell if its bad, the car also bucks/misses at very low throttle once its warm. So if anyone knows why it dose that that would be awsome. also its not throwing a code about the sensor i just is doin the same things my moms car did when her sensor was bad. im also getting really bad gas milage. thanks in advance. Nate
Old Sep 4, 2008 | 03:54 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: How to tell if o2 sensors bad?
pull the o2 sensor and shake it, if it makes a rattling noise when you do, its toast.
Old Sep 4, 2008 | 04:33 PM
CamaroRider's Avatar
I agree. On my 1995 Concorde I pulled mine and found that they had a => very small <= rattling noise. I replaced both of them (my car has only two) and my SES light no longer goes off and on as I drive. This problem did NOT leave any problem codes. I just took a wild guess because the car ran fine (even passed E-check with the SES light acting up) and the O2 sensors were about due for a change anyway.
If you have bad mileage it might be something that CAUSES the O2 sensors to start reporting a problem.
Check all of your vacuum hoses for starts. Make sure they are in place and not cracked (leaking) at the connections.
Old Sep 4, 2008 | 07:20 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
The best O2 sensors run 100,000 miles some replacements only 30,000, this is off the spec sheets.
Yes, think of them as spark plugs, if the plugs are not lasting the O2 will foul up also (think about oil or carbon).
Old Sep 4, 2008 | 08:54 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
thats what i was thinking did it the car only has 65k miles so im thinking just because it sat for a year it went out. im gonna replace it when i get the cash, their only like 20 bucks right? lol another stupid one my car only has 1 right?? jk i know
also the car never throws a code tho i just comes on after a while cause of the cat not being their
Old Sep 4, 2008 | 09:42 PM
Joelfke's Avatar
Car: 1991 Camaro RS Conv
Engine: 305 V8
where is the O2 sensor located exactly??
Old Sep 4, 2008 | 10:16 PM
89Formula_350's Avatar
Car: 89 Formula 350 Firebird
Engine: L98 350 TPI
Transmission: stock auto
Older camaros and birds should only have one ... on either the passenger or drivers side exhaust manifold. Later 4th gen and the most modern cars of today have 4 ... or maybe even more ... on both the passenger and drivers side exhaust manifold both before the cat and after the cat.
Old Sep 4, 2008 | 10:24 PM
Joelfke's Avatar
Engine: 305 V8
so its definately ON the manifold?
Old Sep 4, 2008 | 10:34 PM
On my 1989 305 FI Vin E (TBI) it is on the driver side manifold. If you climb under the car near the driver's side front wheel and look up it sticking out and easily seen.
Old Sep 4, 2008 | 10:38 PM
Engine: L98 350 TPI
Well, on my 89 firebird it is. I'm not sure if the setup changed so much between 89 and 91 or if it is different between camaros and birds. But yeah, I would put my money on passenger side exhaust manifold.
Old Sep 4, 2008 | 10:49 PM
Joelfke's Avatar
Engine: 305 V8
fantastic....my cars getting a random check engine light while randomly driving and im pushing 200k so i think its time to change that and probrably other sensors
THANKS
Old Sep 5, 2008 | 06:18 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
mines on the drivers one
Old Sep 16, 2008 | 11:04 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
91z 2 8 did this fix your problem?? I just started to have the same problem, car idles ruff once in closed loop. It runs fine going down the road and when it in open loop, but at idle acts like it cammed
Also, I'm not throwing any codes..I have a autoXray, what should I look for??
Cornholio7979
Sep 20, 2018 02:31 AM
bryanwood74
Sep 24, 2015 09:50 PM
GTAman
Sep 21, 2015 09:57 AM
squiggy2
Aug 9, 2015 09:30 PM
