dont even know where to start....im stuck help
Old Sep 26, 2008 | 08:58 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
I am fed up with my motor runnin like ****! I jump the A and B obd1 port under the dash to show codes and nothin will blink the check engine light just stays on. Also one of my fans kicks on as soon as i turn the key on and it will never shut off. When i can get the motor to start it only runs on 7 cylinders and it smells very rich.....the intake screams like crazy so i know the IAC must be way off. i have tryed to jump the A and B and pull the IAC and Timming light with the key on to reset the IAC but i dont think it did anythin. I have tunnerpro RT and the Ostrich to tune with but not sure where to even start with this POS haha just upsets me that it wont even idle very well at all! any help would be great at this point thanks guys
Old Sep 28, 2008 | 12:33 AM
jp sunshine's Avatar
Car: 87 TransAm
Engine: 5.7
Transmission: 700-R4
Axle/Gears: Stock
Re: dont even know where to start....im stuck help
Turn the key to on position without starting the car and listen for the fuel pump to energize...if there's a delay or you don't hear it there might be a problem in the ignition switch which might fool the ecm into thinking the ignition is not on...no codes will flash. As far as the 7 cylinders...do you know which one is not firing? Is it an electrical, fuel delivery, or mechanical problem? Without specifics it's hard to diagnose, but in a case of multiple failures like yours, I would focus on one problem at a time. Start with the dead cylinder...9 times out of 10 it's a simple fix.
Old Sep 28, 2008 | 03:53 PM
Car: 92 1500p\u 2wd
its the #1 cylinder thats not firing....also when i turn the key on the pump charges and as soon as it kicks off the one fan kicks on and stays on!
tmellott89
Oct 14, 2015 02:06 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
HikoriYami
Sep 21, 2015 07:11 PM
steimel94
Sep 20, 2015 12:46 PM
ctoledo0834
Sep 18, 2015 04:16 PM
