plenum ported to 52mm tb
Old Oct 5, 2008 | 11:18 AM
jmmass's Avatar
Car: 86 camaro irocz z28
i recently got a 52mm tb but im thinking that i should have my plenum ported to get more hp out of the setup. will that give me a noticable difference? also should i get larger runners while im at it? thanks
Old Oct 5, 2008 | 08:52 PM
Damon's Avatar
Re: plenum ported to 52mm tb
Bolt it up, open the throttle all the way and look down the bores. I haven't found that it's far off with a 52mm unit. 58 defintely takes work, but 52 is usually pretty a pretty good match, even bolt-on.
Bigger runners are a different discussion. Almost always helpful in a performance application but there are many different styles/brands with their own plusses and minuses.
Reid Fleming
Oct 10, 2015 09:56 PM
toronto formula
19
Oct 6, 2015 12:27 PM
bplessy
Sep 30, 2015 12:14 PM
