My car passes CA's smog test
Old Oct 15, 2008 | 01:25 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Who says you cant have power and be "green" at the same time??
15 MPH:
HC: max 110, meas: 93
CO: max 0.71, meas: 0.70
NO: max 772, meas: 42
25 MPH:
HC: max 85, meas: 79
CO: max 0.59, meas: 0.45
NO: max 711, meas: 62
My HC (hydrocarbons) and CO (carbon monoxide) numbers are close to max, meaning I'm a little bit rich. I'll have to adjust the low-rpm tables a bit to compensate. Having 30lbs injectors will do that. But that NO value (nitrogen dioxide) being that low means the EGR is really working.
The cats are 2+ years old too, not new.
Click here for my mods!
All I need now is a better 1/4 mile ET to go with my horsepower/torque numbers, and I'll have one of the best daily driven thirdgens in SoCal!
Old Oct 15, 2008 | 09:49 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: My car passes CA's smog test
15 MPH:
25 MPH:
Nice job. It all boils down to a delicate balance of fuel and timing. Even a proportional gain and duration that is too large or small for the current injectors will cause you issues. If it cycles too rich for too long it will increase your HC and CO, if it cycles too lean for too long, it will raise your HC and NOx. I was able to get this from a Dart Iron Eagle headed 355 TBI with a 214/228 @ .050" roller cam. The engine made 326 RWHP @ 5,600 too.
EDIT- You might also play with the MAP AE filters. I have seen bigger than stock cams have just enough variation to trip the MAP AE and pour in fuel without reason. Also when it comes inspection time, if you were to retard your timing 4-6* across the board, it would help clean up those HCs.
onefreakz
May 14, 2018 12:15 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
wruiz
Aug 11, 2015 02:59 PM
mustangman65_79
Aug 7, 2015 09:55 PM
