My 91 z28 starts and dies only when cold?
Old Oct 28, 2008 | 07:16 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
just started having issues with my 91 z...it start then dies, but if you give it gas when starting it it will run and drive fine, just wont idle when the motors cold. drive it for 5 mins its fine. i changed plugs, coolant temp sensor, and oxygen sensor. any idea? its a 350 tpi with auto trans. no codes either
Old Nov 1, 2008 | 05:44 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: My 91 z28 starts and dies only when cold?
I'm inclined to think the IAC isn't operating correctly, do you have access to a scan tool?
Old Nov 2, 2008 | 12:25 AM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
yea...could be possible. i took it to my local shop and left it there a few days and whenever he tried starting it while cold it started and idled fine. so i took it back home and im gonna see if it starts doing it again. he also thought if it wasnt the cts that it could be the the iac motor. so i'll see what happens.
Old Nov 4, 2008 | 02:39 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
So what happened
Old Nov 4, 2008 | 05:13 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
hasnt really done it anymore...although sometimes it stumbles at idle when driving...the rpm gauge will kinda bounce around. i may just change the iac sometime when i get a few bucks.
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
