91 long cranking when warm
Old Oct 28, 2008 | 07:28 PM
sschevy400's Avatar
Car: 91 z28
Transmission: auto :(
Hey guys, after my 91 was running and got up to temp. If i shut it off and let it sit for a few, it takes a while to start again. It cranks just fine, just wont fire up. I found the trick is to let it crank for 2 seconds, then stop and repeat like 3 times and it will fire up. When the car is cold, it fires right up. Car runs fine once its running.
Any ideas??? just looking for info before i start tearing into it..
Ed
Old Oct 28, 2008 | 09:22 PM
82taluver's Avatar
Car: 1991 GTA
Transmission: M5
Re: 91 long cranking when warm
I personally would check timing first, its easy and quick plus at least you will know where its at ! sounds like its a lil retarded, as too advanced would try to "fight" the starter. oh yeah fuel pressure is definitely a priority to check
Old Nov 17, 2008 | 06:54 PM
Rayvan's Avatar
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
The coolant sensor in the front of the intake manifold may be bad. The one to the left of the hose that leads to the throttle body.
If it's not that, your injectors may be leaking down.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
angel2794
Sep 8, 2015 06:22 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TBRays98
Sep 6, 2015 05:05 PM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
