IAC Valve
Old Nov 1, 2008 | 05:40 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
IAC Valve
I just cleaned my IAC valve and could not remember ever replacing it, so it may be the original. Do these thing wear out or go bad???
Old Nov 1, 2008 | 04:30 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: IAC Valve
Sure they go bad...but ususally thy die and don't move in/out. Can m\be monitored easily enough with a scan tool by watching the IAC counts.
PS...if it's still out, do not appply voltage to it, unless you're in a really confined area and you can locate the pintle
Also, clean the passage ways and seat in the TB as well.
Old Nov 1, 2008 | 05:44 PM
george 88gta's Avatar
Re: IAC Valve
I think the count is controlled by the ECM and what you are seeing on the scanner is what the ECM wants. I dont think the count can be used to verify that the pintle is actually moving, only that the ECM is commanding the pintle to move.
Old Nov 1, 2008 | 05:48 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: IAC Valve
No, the IAC motor is a phase motor, I/e "stepper count" and what you read from a scanner is the counts off the motor, and it's current location/postion (as it tells the ECM where it is at)
Old Nov 7, 2008 | 01:39 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
Re: IAC Valve
if you take it out and there is "slop" or play in it when you try to move it, get a new one. And you'll notice smoother idle and shifts on a stick car.
Old Nov 7, 2008 | 03:18 PM
DJP87Z28's Avatar
Re: IAC Valve
Thanks for all the input.
Old Nov 7, 2008 | 07:55 PM
kit-ss's Avatar
Car: 91 TA
Engine: 355 FR Stealth Ram
Axle/Gears: BW 9 BOLT 3.27
Re: IAC Valve
My TA started normally. but after it warmed up it would idle high. So I checked the IAC and it was broken. So I replace it and set it and now it won't start and stay running without giving it a little gas for a few minutes. After it is warm it seems to idle pretty smooth.
Does anyone know if the ECM is different for a stick car? Even in neutral the idle still doesn't want to come down til a complete stop. I'm a t-56 conversion on an original T-5 but I pulled the ECM the other day and it was a reman from 1995 with a jet chip from 1991. Anyone in J-ville FL have all this tuning equipment they would like to rent? Anyone want to get together and help each other rebuild a couple T-56's?
92firebirdguy
Sep 1, 2016 07:53 AM
sandman92084
Sep 12, 2015 10:27 PM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
