code 12
Old Nov 2, 2008 | 06:00 PM
rock861261's Avatar
code 12
i get code 12 constantly only code 12 will blink and blink past the 3 times i can get my car to idle but not rev or rev very slowly and ideas how to fix this code 12?
91 camaro l98 tpi
Old Nov 2, 2008 | 07:51 PM
CRUSHER's Avatar
Car: 88 Iroc
Engine: 350(300hp G.M crate, supercharged)
Re: code 12
Sounds like you have terminals A and B jumpered. That cant be though ...Code 12 comes on in diagnostic mode, when you jumper A& B to check for trouble codes....code 12 means everything is good...Your getting this after the car is started?....no way, impossible
Old Nov 2, 2008 | 07:53 PM
rock861261's Avatar
Re: code 12
no i have a check engine light on and when i go for the codes all i get is code 12
Old Nov 2, 2008 | 08:34 PM
CRUSHER's Avatar
Car: 88 Iroc
Re: code 12
Then there is nothing wrong...Code 12 is is good(you only want to see code 12 flashing)......No trouble codes are stored in your ECM...If other codes appear other than 12 then there is a problem with one of your engine sensors or a related component
Old Nov 2, 2008 | 08:36 PM
rock861261's Avatar
Re: code 12
then why do i have a check engine light on even after i clear them it jumps back to code 12
Old Nov 3, 2008 | 06:39 AM
pvollman's Avatar
Car: 1986 Trans Am/2002 Trans Am
Engine: 305 V8 and LS1
Axle/Gears: Stock
Re: code 12
Are you clearing the ECM by disconnecting the negative battery cable? Do you have a scanner connected to the ALDL connector to monitor if codes are present when running? As Crusher stated code 12 is the normal flash code; if you are jumping terminals A & B and the check engine light comes on and the fan runs this is normal. If the check engine light comes on after normal operation and running with your jumper disconnected than there is a problem.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
