Iroc running rough
Old Nov 9, 2008 | 08:12 AM
clairecar's Avatar
Car: camaro
Engine: 5.0
Iroc running rough
HI im wondering if someone can help me.
I have just purchased a 85 iroc with the 305 TPI motor.
Everything is stock except for the smog removal.
When i picked the car up it starts hunting on startup and running very rich, so when you drive it it bunny hops until you give it some throttle because the revs are going up and down.
I have changed the IAC valve hoping it was that but its still bad on startup but if you rev it a bit it runs alot better and doesnt run rich but still doesnt sound quite right.
The previous owner has serviced the car which i have checked but will replace the fuel filter anyway
Any ideas?
Old Nov 9, 2008 | 08:22 AM
Guest
Guest
Posts: n/a
Re: Iroc running rough
hows thr egr
Old Nov 9, 2008 | 08:42 AM
clairecar's Avatar
Car: camaro
Engine: 5.0
Is there anyway to check the EGR valve?
Old Nov 9, 2008 | 08:59 AM
clairecar's Avatar
Car: camaro
Engine: 5.0
Im not sure but will have to double check when i see the car again tomorrow, wont the egr be disconnected if the smog/air stuff has been ripped off? will this cause a problem?
Old Nov 9, 2008 | 09:54 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
There are many things that can cause a hunting idle. Leaky injector, ignition problem, leaking EGR, vacuum leak, and the list goes on. You really need someone with a scanner and some skills to see what's happening.
Old Nov 9, 2008 | 10:17 AM
clairecar's Avatar
Car: camaro
Engine: 5.0
I have replaced all the hoses as there were some vacuum leaks, ignition system is fine tested it all the way through, its definatly a fuel problem.
If the egr has been disconected can this cause a problem? Does it need to be connected or removed if the air system is gone?
Old Nov 9, 2008 | 11:51 AM
jv9999's Avatar
Engine: 5.7L/350
If the EGR disconnected and closed tight, it won't effect idle.
Old Nov 9, 2008 | 02:47 PM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
check your Throttle Positioning Sensor if your car if equipped with one. The TPS can be checked with an Amp reader voltmeter tool. I had this problem on my fuel injected iroc z
Old Nov 10, 2008 | 03:03 PM
clairecar's Avatar
Car: camaro
Engine: 5.0
Checked egr today,its disconected but someone has just put some glue in the tube where the vacuum pipe goes on, (is that good enough?). The pipe work is still there which goes to something next to the distributer? Will check the TPS tomorrow. Seemed to be worse this morning sounding like not running on all cylinders and shaking badly when revs applied.
Old Nov 10, 2008 | 03:07 PM
jv9999's Avatar
Engine: 5.7L/350
Doesn't matter if the valve is plugged, as long as the vacuum line to the EGR solenoid is. You might want to just plug it back in. It doesn't hurt performance any, makes it less susceptible to pinging, and lowers NoX emissions. Something else to consider is the distributor. The pickup coils and ignition modules fail pretty frequently. They too can make it miss badly at lower RPMs.
Old Nov 11, 2008 | 12:34 PM
clairecar's Avatar
Car: camaro
Engine: 5.0
Ok thanks, got some things i can check out, the vacuum line to the egr solenoid is open at the moment, Also car started to backfire today on tickover?
Old Nov 12, 2008 | 02:34 PM
clairecar's Avatar
Car: camaro
Engine: 5.0
Put a new bulb in the service light as previous owner had removed it and got code 33 which i think is mass air flow sensor? can i fit one off a 86 tpi car just to see if its the problem or are they differnet on a 85?
Old Nov 12, 2008 | 03:22 PM
jv9999's Avatar
Engine: 5.7L/350
I'm pretty sure '85 was a one year sensor.
Old Nov 14, 2008 | 12:25 PM
clairecar's Avatar
Car: camaro
Engine: 5.0
Ok, replaced the fuel filter and spark plugs today doesnt miss anymore but still hunting. Does the IAC need to be setup like in the technical guide? as my rev counter is shot and with it hunting i cant get a accurate rpm to set it up.
Also seems to run ok when warmed very slightly, then when cooled down and re-started it starts hunting again. any ideas?
Old Nov 14, 2008 | 05:02 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Check that the TPS is at .54 volts at idle. Ohm your injectors when they are cold, and again at operating temperature. Make sure the vacuum lines are all connected and in good condition. Check that the egr valve moves freely up and down. Check the spark plugs and the wires. If you mist the plug wires with water and start the engine in the dark, you will be able to see cross-sparking if the wires are bad. Post your results after checking these things.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Bradsaundry
Aug 12, 2015 12:34 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Sherpajames
Aug 7, 2015 06:56 PM
