will this cam peform? look at my setup
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
ok well
i have trick flow 23degree alum heads 195cc runners and 64cc chamber,
accel super ram with edelbrock hi flo tpi base,
comp cams 1.6 roller mag rockers
ford svo 24lb blue tops injectors
edelbrock tpi shorty headers
all tuned with prominator
now will this cam work decent and compliment the super ram.
crower part # 00402LM
lift with 1.6rockers is 531 INT 553EX
heres the spec card
http://www.crower.com/misc/cam_spec/...part_num=00402
heres the spec card
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: will this cam peform? look at my setup
It should work well.
Mine is very similar. (from Crower)
277/286
225/232 @.050
.531/.553 1.6
114 LSA installed on 110 centerline.
9.70 compression E-tec 200's
12.80@108 in the 1/4
But I would get rid of the TES headers.
277/286
225/232 @.050
.531/.553 1.6
Street Lethal
Apr 30, 2019 12:14 PM
