Also having cold start problems
Old Nov 11, 2008 | 12:44 PM
yeah low's Avatar
Guys, I have read the specific topics on this subject, and I have learned a great deal of info. My problem is decidedly different.
I got a 305, with a variety of TPI parts assembled and a harness from FIC. My issue is that when I try to cold start, it will not start, until I squirt raw fuel in the TB. After that it will start as long as it is warmed up somewhat. (Approximately 15 seconds of running.) I got nearly 50 PSI fuel, return line doesnt seem to be blocked, and when I hit the key I DO get a 2 second fuel pump cycle... My system HAS the 9th injector, but my fuel rail has no provision for it. I had assumed the FIC harness (based on a 92 SD type system) had already factored in cold starting. I have harassed FIC enough with my various VSS questions, and such so I dont want to bother him any more...
Can you guys offer advice on what to look at?
Scott AKA YL
Old Nov 11, 2008 | 01:19 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Also having cold start problems
Is your chip programmed to delete the 9th injector?
Old Nov 11, 2008 | 02:33 PM
yeah low's Avatar
That is my assumption, yes. When I recieved the kit, I got a ECM, wiring harness, and instructions. These instructions say that the system is based off a 1992 Chevy Camaro, and that is what I am to buy my misc sensors for. Thus, I have. Could there be a difference in the TPS sensor? I did adjust it to .510 volts with KOEO. I read that is the correct value...
Thanks.
/YL
Old Nov 12, 2008 | 05:57 AM
scottydta's Avatar
Car: 1989 Trans Am
Transmission: 700R-4
after getting it warmed up and running, i would check your initial timing again.
Old Nov 12, 2008 | 09:14 AM
yeah low's Avatar
guys I just heard this:
Is it possible that the flywheel/starter combo spins too slowly??? I have the bigger flywheel, and starter, which do turn slower than the smaller flywheel. :-/
Thanks YL
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
