T.P.I Problems
Old Nov 11, 2008 | 07:39 PM
alek72us's Avatar
Car: 1991 Camaro z28
Engine: TPI 350
Transmission: Auto 700-4r
Axle/Gears: 3,23
T.P.I Problems
I have a 92 camaro b4c (police interceptor) tpi 305 speed density. i bought it when i turned 18 rode it to hard spun a rod bearing i took it to the shop and they put the stock z28 back in it they didn't know that in 92 they had two differant 305's that year well either did i (they put the smaller cam in it and 1.5 rockers) when i got it back it starts right up then about two min after running it starts lopeing really bad then dies. and when i drive it i will start doing it and try to die when i'm driving and when i'm driving at one constant speed the check engine light will come on. i have talked to a bunch of people about it they all tell me its not the cam i just figured i would put it back to what the computer wants and if i still have the problem go from there. sorry about the long story. doe sanyone know what it is. please help me out the car was bad fast for stock when i got it now its slow i lost a lot of power
Old Nov 12, 2008 | 11:17 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: T.P.I Problems
What Check Engine code is it throwing?
Old Nov 12, 2008 | 01:13 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: T.P.I Problems
ECU.
Old Nov 18, 2008 | 08:09 PM
alek72us's Avatar
Engine: TPI 350
Axle/Gears: 3,23
Re: T.P.I Problems
well i found out my oxgen sensor is bad so i'm going to replace that then see if it fixes my problem
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
