TPS or MAP Experience needed..Pls Help!
Old Nov 18, 2008 | 04:08 PM
jshepit's Avatar
Car: 1988 IROC
Transmission: BW 5-Speed
Axle/Gears: 3:73
My 305 TPI starts and idles great. Once I start to drive it, it has an engine miss/buck during accerlation that I can't seem to isolate. Has everyone experienced this problem and found it to be the TPS (even if it tested good) or the MAF (even though it seems good)? If I jumper the ALDL pins A and B it runs fine. Everything else on the engine has been tested or replaced. Recent tune-up, fuel pump (pressure fine) and many new sensors (MAF pwr rly and burnoff rly replaced, OS, temp sensor). I could really use some insight?
Also, will it damage the engine if I operate it while the ALDL is in Field Service Mode (Pins A and B Jumpered)?
thanks a ton.
Jeff
Old Nov 18, 2008 | 10:06 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: TPS or MAP Experience needed..Pls Help!
thanks a ton.
Jeff
You can check the TPS with a voltmeter. Just make sure it increases smoothly with the throttle. Sounds like it could be ignition to me. Wires good? Plugs good? I'd be thinking of putting an ignition module and pickup coil in the dist. They are common problems and fairly cheap.
Old Nov 19, 2008 | 01:41 PM
jshepit's Avatar
Car: 1988 IROC
Axle/Gears: 3:73
Yes, all wires and plugs have been replaced. Thanks for the heads-up on the ignition components. I will replace them next.
Do you know why it would run ok though with ALDL pins A and B jumpered? I've been asking this questions a lot, but can't get an answer and not sure where to go to get it.
thanks again,
Jeff
Old Nov 19, 2008 | 01:49 PM
jshepit's Avatar
Car: 1988 IROC
Axle/Gears: 3:73
Oh, I did check the TPS a couple times in the past and it seems to test ok. Injectors test good cold, havent tested warm yet.
thanks,
Old Nov 19, 2008 | 02:02 PM
jv9999's Avatar
Engine: 5.7L/350
thanks again,
Jeff
I'd have to look in the shop manual to be sure, but I'd guess it disables the EST.
Old Nov 19, 2008 | 02:10 PM
jshepit's Avatar
Car: 1988 IROC
Axle/Gears: 3:73
I'm drawing a blank on what the EST is?
Old Nov 19, 2008 | 02:38 PM
jv9999's Avatar
Engine: 5.7L/350
Electronic Spark Timing.
Old Nov 20, 2008 | 01:22 PM
jshepit's Avatar
Car: 1988 IROC
Axle/Gears: 3:73
Isn't the electronic spark timing (EST) managed by the Ignition Module (IM) (and Pickup Coil) in the distributor? I've looked through my manuals on this TPS system and I haven't determined is there is a seperate module for the EST or is it controlled by the IM as mentioned above. I do have a new IM that I haven't installed yet. Maybe I'll put it in.
Any other thoughts?
Old Nov 20, 2008 | 01:28 PM
jv9999's Avatar
Engine: 5.7L/350
Any other thoughts?
It's managed by an EST module which is up by the relays (above brake booster) until '88 and then built into the ECM in later years. In either case, it's enabled by the ECM. I've never seen the EST module itself fail, but I'm sure it happens.
Old Nov 20, 2008 | 01:44 PM
jshepit's Avatar
Car: 1988 IROC
Axle/Gears: 3:73
Got it! Thanks! right where you said it was. My book called it an Electronic Spark Control Module. So your thinking this Electronic module is possibly disabled when you jumper A and B terminal in ECM? Any chance you can verify this for me? Or suggest where to find out? And if it does, is the ECM managing spark timing when the ECM is in Service Mode?
thanks a ton, Jeff
91 SrS
Oct 7, 2015 04:32 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
