Backfiring Problems. Please Help......
Old Nov 20, 2008 | 04:16 PM
marolife03's Avatar
Car: 85 Z28
Transmission: 700R-4
Im working on my brother's '90 Iroc. We recently swapped out the exhaust manifolds for a set of Edelbrock Headers & Y-Pipe (Jeg's Part # 350-68762) and ever since then we have been getting backfires. I already checked the timing, timing chain, I even went ahead and did a head job (due to a bad diagnosis of suposivly having bad valves.) The car continues to backfire. We also removed all of the AIR/Smog stuff. Including removing the smog/air tubes off the headers, removing the diverter valve, dis-connecting/unplugging the smog pump, both cats came off, and we blocked off the egr valve. A buddy of mine is telling me that the removal of the AIR equipment is the reason for the backfires. I read the entire sticky on removing the AIR stuff, and nobody else seems to be having this problem. Im fresh out of ideas . Please....any help, ideas or suggestions are appreciated. Thanks
Old Nov 20, 2008 | 11:29 PM
jshepit's Avatar
Car: 1988 IROC
Transmission: BW 5-Speed
Axle/Gears: 3:73
Re: Backfiring Problems. Please Help......
when does it backfire? during acceleration or at idle? Through exhaust or intake?
Old Nov 21, 2008 | 07:54 PM
marolife03's Avatar
Car: 85 Z28
it backfires during deceleration through the exhaust. Any help is needed/appreciated. Thanks
Old Aug 2, 2009 | 07:14 PM
rubbersiidedown's Avatar
Did you figure it out ?
tyeo098
Nov 30, 2015 06:27 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Racerx974
Sep 19, 2015 10:16 AM
