maf problem?
Old Nov 29, 2008 | 10:35 AM
rock861261's Avatar
maf problem?
ok guys 91 camaro 350 i have a real low idle so i thought maybe my maf connector was unplugged(its broken bought a new one but not here yet) i plugged it back in and my car runs up to 2000rpm then will jump to 3500 like its in neutral then shift only after 4000rpm then it will run all the way to redline in 2nd any ideas bad trans or can the maf do this
it will not start with the maf cable unplugged
Old Nov 29, 2008 | 10:02 PM
rock861261's Avatar
Re: maf problem?
any one really need some help here
Old Nov 30, 2008 | 05:19 AM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: maf problem?
91 z28's dont have a maf(mass airflow sensor)if I remember. It should be a speed density system with a map sensor.
Old Nov 30, 2008 | 05:50 AM
rock861261's Avatar
Re: maf problem?
your right i meant map sensor
chazman
Aug 28, 2018 03:25 PM
GTAman
Sep 21, 2015 09:57 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
