very rough idle
Old Nov 30, 2008 | 10:38 PM
Rainman's Avatar
Car: 1989 Firebird Formula
Transmission: WC T-5
Axle/Gears: Moser 12 bolt, 3.73 gears
very rough idle
ok i have a very strange problem that has me confused.
when i start my car it idles and runs fine. problem starts after about 10 or 15 min it barely holds an idle. it starts to die but then comes back to life and keeps doing this until i give it more gas and take off. sometimes the idle gets so bad that it dies and wont start again unless i jump it.
as far as i can tell my TPS is in proper working order. im sure that its a sensor that is going bad but dont know which one.
my car has sat for a while because i ride my motorcycle everywhere and that might be a part of the problem.
any suggestions would help. i have thought about ripping off the TPI setup and putting on a carb but i have also thought of just selling it.
Old Dec 1, 2008 | 05:00 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: very rough idle
Could be a sticking IAC valve. I would remove it, clean it up, and then set adjust minimum air and the TPS. Directions:
https://www.thirdgen.org/tpimod2
It could also be a vacuum leak, make sure all vacuum lines are connected and not leaking.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
