Can a prom set injectors wide open?
Still having a flooding problem, wondering if a bad prom can make injectors run wide open all the time? just replaced the ecm and checked all the ground wires... so i have eliminated those options...
Re: Can a prom set injectors wide open?
Have you checked the CTS and the CTS connection? it's a much more likely suspect
Yes, instead of typing it all out here, check this little chart:
http://www.vettemod.com/forum/showthread.php?p=27413
mdtoren
Aug 16, 2015 05:45 PM
