What's holding my fuel rails on?
Old Dec 6, 2008 | 11:03 AM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I'm changing injectors. I've removed the plenum and runners and four bolts that hold the rails to the manifold, and though I can wiggle the fuel rail assembly a little, it doesn't want to lift off. I don't want to pry on it since the whole assembly looks a little fragile.
Am I missing something, or are the injectors just stuck in there good?
Old Dec 6, 2008 | 11:36 AM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
Re: What's holding my fuel rails on?
Well also you want to make sure that you have disconnected the fuel line that runs to that, dont know if you did or not, then you will have to do a little tugging on it but not real hard, your seals might be stuck a little bit.
Old Dec 6, 2008 | 11:59 AM
DAVEY420's Avatar
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Yeah it takes a little bit of leverage to get the bottom o-rings to pop out.
Old Dec 6, 2008 | 03:25 PM
Engine: tpi 305
OK thanks. I'll get back on it this evening. Busy polishing the runners and plenum right now. Major grunt work.
Old Dec 6, 2008 | 05:00 PM
S105.7's Avatar
Car: '87 S10 Blazer & '91 RS
Engine: L98 & L03
Transmission: 700R4 & T5
Axle/Gears: 10 Bolt/3.73/3.42
Don't forget the bolt on front of the manifold that holds the fuel lines.
Old Dec 6, 2008 | 05:45 PM
Engine: tpi 305
Didn't see that one. I'll get it. Thanks
Old Dec 8, 2008 | 12:45 AM
Engine: tpi 305
BTW, twisted the head off. Just my luck.
Last edited by redliterunner; Dec 8, 2008 at 12:51 AM. Reason: Automerged Doublepost
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
djmarch
Aug 9, 2015 05:27 PM
92projectcamaro
Aug 6, 2015 01:20 PM
