LB9 Fuel Injector OHM's check (cold)
Old Dec 6, 2008 | 04:02 PM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
I put the T/A in storage a couple of weeks ago.It was missing in all gears the day I put it away (what a **** off) anyway I started doing all the checks (spark plug gaps, plug wires, I put a new fuel filter on about 2 months ago).
The injectors are the original Multecs, here are the results from a ohm check (cold).
Cylinder # 1 - 16.1
Cylinder # 3 - 15.8
Cylinder # 5 - 15.6
Cylinder # 7 - 15.5
Cylinder # 2 - 15.9
Cylinder # 4 - 15.8
Cylinder # 6 - 15.8
Cylinder # 8 - 15.7
Does anyone know if these look like they are in spec or need to be replaced?
Old Dec 6, 2008 | 10:17 PM
southbay08's Avatar
Re: LB9 Fuel Injector OHM's check (cold)
ohms are within range. Have you considered having them cleaned?
Old Dec 6, 2008 | 10:46 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Cylinder # 1 - 16.1
Cylinder # 3 - 15.8
Cylinder # 5 - 15.6
Cylinder # 7 - 15.5
Cylinder # 2 - 15.9
Cylinder # 4 - 15.8
Cylinder # 6 - 15.8
Cylinder # 8 - 15.7
southbay, why don't you tell him that multecs have to be checked hot. They get turn to turn shorts that can only be detected by an impedance bridge not an ohm meter. When hot the short mostly shows up with an ohm meter. Do you use a bridge to check injectors? Do you even know what one is?
Old Dec 6, 2008 | 11:10 PM
southbay08's Avatar
that wasn't necessary
Old Dec 7, 2008 | 07:41 AM
Car: 89 T/A
Engine: LB9
Thanks for the replies Southbay and irocuroc,when the car comes out of storage in May I'll do the hot test as well.
Oh, irocuroc what is a "impedance bridge"?
Last edited by 89transam*pearl; Dec 7, 2008 at 07:43 AM. Reason: Automerged Doublepost
Old Dec 7, 2008 | 09:42 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
why is it not nessasary it the best test for a coil. They have been in use since ww2. A ohm meter can not determine a coil short if it only is there when hot or the. Ohm meter will work when they are hot ask any electrical engineer
You are misinformed if you just use a ohm meter
Old Dec 9, 2008 | 04:56 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Also note that testing resistance of them only ensures that they're electrically okay. It could still be possible that one of them is clogged or sticking. You might try tapping on each injector with a screwdriver while the engine is running, and seeing if anything changes.
Old Dec 10, 2008 | 04:13 AM
Car: 89 T/A
Engine: LB9
Thanks Ward,I"ll give that a try.
Old Dec 13, 2008 | 02:14 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Checking cold with an ohm meter isn't worthless though. My old injectors tested from 9 ohms to 14 ohms sitting on my kitchen table. As cold as could be.
Old Dec 18, 2008 | 02:45 PM
stampede52's Avatar
why not try a hammer i saw it in a fic video
Old Dec 18, 2008 | 03:56 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
I think the hammer was too prove they were seated to show the height difference.. Never hit a injector with a hammer, only a crowbar.
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
Brcharrelson
Aug 26, 2015 07:47 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
