MAT sensor is 'where'?? (scratches head)..
Old Dec 8, 2008 | 09:05 PM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I did search after search and still can't figure out where the MAT is actually located. Somewhere in the back and 'underneath' the TPI intake??? or? Can't find it here nor in the manual.... Feeling kinda dense. Nitro
Old Dec 8, 2008 | 09:58 PM
Guest
Guest
Posts: n/a
Re: MAT sensor is 'where'?? (scratches head)..
Speed density? lol
Anyway, its under the plenum near the back. Its somewhere behind the EGR but before you get to the distributor. Faces downward, and I'm not sure it can be removed without taking the plenum off, never tried that.
Old Dec 8, 2008 | 11:29 PM
neagan's Avatar
Okay, I know which one it is now. I've siamesed and match ported my TPI but had no idea what that one sensor was and have since forgotten about it. Anyone know how to describe what would be the effects if it was disconnected or even faulty?
Thanks for the info. It just amazes me that a chilton's and Haynes manual won't even mention the MAT & it's sister CTS.....
Nitro-Nicky now not so dense-
Old Dec 8, 2008 | 11:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its one of the things the computer checks, so you'll get an SES light if its disconnected or faulty. If its reading 20 degrees too high or too low you probably wont notice it. The computer will adjust the fuel based off its reading.
Old Dec 9, 2008 | 10:18 AM
neagan's Avatar
Thanx Kevin-
I've been chasing one of those long term gremlins & want to cover all my bases
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
bamaboy0323
Sep 3, 2015 06:07 AM
