tpi interchange questions?
Old Jan 4, 2009 | 04:04 PM
2fast4love's Avatar
i have a tpi system out of a 91 vette speed denisty, can i use it with a maf computer. i know it would require all the sensors but can it run the system. thanks
Old Jan 4, 2009 | 09:54 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: tpi interchange questions?
Yes, the physical intake doesnt care what computer you use to run it.
Old Jan 4, 2009 | 10:25 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
the only thing is what about the maf burnoff, is'nt this controlled by the ecu.
Old Jan 5, 2009 | 11:19 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
If you run it with a MAF, you have to use everything that goes with a MAF system. And I mean "everything"
Old Jan 5, 2009 | 04:09 PM
2fast4love's Avatar
ok now iam getting mixed anwsers, i have the complete harness with car its an 88. but a buddy of mine gave me a 91 tpi off of a vette so i cant to put the vette tpi on it. will it run minus the cold start injector im not using it now thanks
Old Jan 7, 2009 | 08:23 PM
2fast4love's Avatar
bump
Old Jan 8, 2009 | 01:20 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
My TPI is an '88 IROC-Z with a stock 1227165 ECM and a '89 ARAP bin 6E mask which deletes the Cold Start circuit.
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
