fuel pump
Old Jan 13, 2009 | 08:29 PM
joffer00's Avatar
Car: 1991 Z28 hard top
Engine: 5.7 350 v8
Axle/Gears: 10 bolt w/ 3.42
fuel pump
so i think my fuel pump s weak and dying is there any way to replace without dropping the tank???? any ideas???? how can i test to see what pressure its putting out anyways????
Old Jan 13, 2009 | 08:35 PM
joffer00's Avatar
Engine: 5.7 350 v8
Re: fuel pump
k so im stupid and fuel pressure gauge wil test it but i still need ideas on replacing it if that is what it needs.
Old Jan 17, 2009 | 08:49 PM
xpbxwrecked1's Avatar
Car: 87 mustang gt 89 camaro
Engine: 302 355 tpi
Transmission: manual
Axle/Gears: 3.55 and 3.42 posi
Re: fuel pump
just drop the tank its not too hard, only other way is to ct a hole behind the rear seats
Old Jan 18, 2009 | 11:56 AM
rs_racer_20's Avatar
Car: 92 RS
Engine: 3.1 (191) V-6
Transmission: 700-R4
Axle/Gears: pos track
Re: fuel pump
yea is not that hard just loosen the two belts that are holding it and you good to go
Old Jan 18, 2009 | 08:35 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
Re: fuel pump
not too hard? just remove 2 bolts?
its been my understanding you have to drop the rear axel and exhaust? no?
Old Jan 18, 2009 | 08:43 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: fuel pump
yes
Old Jan 21, 2009 | 07:47 AM
bryan1990irocz's Avatar
Re: fuel pump
Originally Posted by 1piece@atime
yes
yeah you have to drop the rear end and remove the exhaust from the cat back. i have the same problem with mine right now. the only thing i can't figure out is how to siphone the gas from the tank. i seem to be running in to something in the tank. the tank is full and i can't even touch any fuel.
Old Jan 21, 2009 | 05:43 PM
Re: fuel pump
try to pull the filler neck off at the tank and soo if you can slip your siphon in there. if that doesnt work just get help and or a transmission jack and pull it with a full tank.
Old Jan 27, 2009 | 09:46 AM
joffer00's Avatar
Engine: 5.7 350 v8
Re: fuel pump
yeah i cut the exhaust and tried to drop the tank to no avail because i thought i had like a quarter tank an it was more like 3/4 so i put it back together and cut a hole. turns out the pump wasnt the problem anyways, thanks for the help guys
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
