heads on a 305 tpi
Old Jan 20, 2009 | 11:30 AM
devildog20's Avatar
Car: 1988 Iroc-z
Engine: powerhouse 335 stroker
heads on a 305 tpi
alright i have a powerhouse 335 stroker with the origional 305 tpi heads my question is if i can use 202 tornado heads with my engine i don't really know too much about what heads i can use
so any help would be great
Old Jan 20, 2009 | 01:19 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: heads on a 305 tpi
What's the casting numbers on the heads you have now?
It's stamped on the head between rocker studs.
The ones ending in "416" are very good when ported with performance valve job.
Old Jan 20, 2009 | 09:14 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Everything I've read here says no you cant use 2.02 valves with a 305's small bore. You're stuck with heads that are 1.94" intake valves.
Old Jan 21, 2009 | 11:19 AM
David 91RS/Z28's Avatar
See if you can find any Aluminum L98 Vette heads. Have them ported w/ a valve job and that should wake up that 335. Or better yet throw on some of the 180cc AFR's. Definitely stay small on the valves or they will just be hogging up the cylinder area which will cause shrouding. IMO, heads are the most important area to look at so don't be afraid to spend a little extra money on professional porting or good aftermarket ones. You will be rewarded in the end.
Old Jan 23, 2009 | 04:37 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Maybe this will help.
https://www.thirdgen.org/forums/tpi/...formation.html
Also, see the thread above entitled Vortec heads?
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
