bad fuel pressure regulator??
Old Jan 24, 2009 | 01:20 AM
hart7631's Avatar
i just changed intake gaskets on my 89 350 tpi motor... went to start it and the vacume hose coming off the pressure regulator is just peeing gas into the plenum. im guessing the regulators bad but could it be somting else? like cloged injectors or a bad vacume line? thanks for your help!!!
Old Jan 24, 2009 | 02:08 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: bad fuel pressure regulator??
sounds like a bad diaphragm. The vacuum line never sees gasoline...
Old Jan 25, 2009 | 04:40 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
FPR is the only thing going on here. Diaphram ruptured is the only way gas can go through that vacuum line. Change that and you will be fine.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
