Cylinder Head Porting Shops
Old Jan 25, 2009 | 05:37 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
Does anyone know of a well established and reputable automotive machine shop that has expertise in cylinder head porting. I am considering purchasing better cylinder heads and would consider shipping them to such a shop for porting then having them shipped to me. I did a search on the internet and found a few shops in North America, but really I do not know their work. Thanks.
Old Jan 25, 2009 | 11:51 PM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
Re: Cylinder Head Porting Shops
Hey BC, from what I understand your better off just buying a good aluminum head from one of the several manufacturers. By the time you get a stock type head ported and rebuilt the price will be comparable to a good set of aftermarket heads which will blow them away. Check out the AFR eliminators, they are reaching legendary if not almost mythical status here in the states. I'm kinda tied up financially right now so I'm learning to port my own heads and intake. The intake on our cars (if yours is TPI) will limit the heads flow at some point. This is where home porting shines! (Or Extrudehone which is about 20 mins away from my house!) Not an expert just my opinion from researching this. Oh and to answer your question I don't know any shops that port heads except for Extrudehone which are very good but exspensive. Ciao.
LT1Formula
20
Nov 14, 2015 12:02 AM
NinjaNife
Aug 23, 2015 11:49 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
