350 cam
Old Feb 7, 2009 | 03:24 AM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
350 cam
I have a stock 87 GTA 350 auto, Im looking into upgrading the cam.
Was checking out comp cams 270HR and 280HR.
Plan on keeping the stock intake with 22lbs injectors with afr, any suggestions for a street/ strip cam?
Old Feb 7, 2009 | 07:35 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: 350 cam
I'm no expert but the 270 strikes me as the upper limit for stock intake/heads.
Old Feb 9, 2009 | 04:33 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 350 cam
Its my opinion that its not worth it to swap the camshaft on a stock engine. You have to remove so much of the top end that its pointless to put it all back. Save your money and do the camswap at the same time you do the timing chain and intake upgrades.
Or do the cam and heads at the same time so you can use bigger and better camshafts.
Lastly, keep in mind with a cam swap, you'll gain a lot more power if you reprogram the computer, too.
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
michealleger
Aug 26, 2015 03:29 PM
Eric-86sc
Aug 24, 2015 09:01 PM
theshackle
Aug 22, 2015 06:52 PM
